Itr seats
Old Jul 27, 2002 | 03:39 PM
silvercivicsir's Avatar
Default Itr seats
Just a question, do your passenger side seats slide forward when it's tilted ie you pull the handle to tilt the seat forward ?
I just installed a set of itr into my civic, and the passenger seat does tilt forward, but doesn't slide forward like before [ the slider works perfectly, but you must pull the handle underneath the seat].
Also do you guys know if I can only swap the inner rail to fit the civic ? cuz thats all i did, however they seem not to "straight" and a little crooked
Old Jul 27, 2002 | 03:51 PM
Ideal R's Avatar
New User
Default Re: Itr seats (silvercivicsir)
It doesn't slide forward unless you use the little handle thing that is at the "hinger" part of the sit.
Old Jul 27, 2002 | 08:14 PM
VADE-R's Avatar
New User
Default Re: Itr seats (Ideal R)
i'm pretty sure mines tilts and slides @ the same time.
Old Jul 27, 2002 | 08:17 PM
98itR484's Avatar
Default Re: Itr seats (VADE-R)
mine tilts and slides at the same time
Old Jul 27, 2002 | 08:50 PM
TypeR 599's Avatar
Default Re: Itr seats (98itR484)
same
Old Jul 28, 2002 | 12:01 AM
Keyed ITR's Avatar
Default Re: Itr seats (TypeR 599)
I wish the seats would slide back into their original position. My brother's CL slides into that position electronically and cars like late model Volkswagens have a regular device that switches back.
Damn those cars that have that feature...damn them.
Old Aug 11, 2002 | 04:12 PM
halltd's Avatar
check the bottom of the seat. most likely the cable that is under there is stuck or came unhooked when you installed it. that's probably your only problem.
Old Aug 11, 2002 | 04:16 PM
Rob :190:'s Avatar
Default Re: Itr seats (halltd)
mine used to slide forward as well as tilt
rob- checking under his seat right now.
Old Aug 11, 2002 | 04:27 PM
01-1293's Avatar
Default Re: Itr seats ( Rob)
i'm sliding and tilting AT THE SAME TIME
Old Aug 11, 2002 | 04:36 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Passenger side slides and tilts. Driver side only tilts.
Old Aug 11, 2002 | 04:38 PM
ITR#132's Avatar
e13h
Feb 20, 2019 10:54 PM
Porsche944Turbo
Oct 1, 2016 01:20 PM
RDLIN-IT
Jun 17, 2004 01:26 AM
RTW DC2R
Jan 24, 2004 05:42 PM
RiceRacist
Sep 18, 2003 11:16 PM
