GSR Overheating
Old Oct 4, 2008 | 06:02 PM
SpoonPowered's Avatar
Default GSR Overheating HEEEEELLLLLLLLPPPPP
Hey why could my buddys GSR be overheating if he has changed thermostat, resurface the head, new headgasket, new oem water pump, new timing belt.
Could it be a bad block and is it fixable?
Modified by SpoonPowered at 7:10 PM 10/4/2008
Old Oct 4, 2008 | 06:26 PM
IntegraType-R's Avatar
Default Re: GSR Overheating HEEEEELLLLLLLLPPPPP (SpoonPowered)
run your motor and take off your rad cap, if u see bubbles in there or your res its a hg leak
narrow it down..
either that or your themo is bad.. and its not opening up
Old Oct 4, 2008 | 06:31 PM
Default Re: GSR Overheating HEEEEELLLLLLLLPPPPP (IntegraType-R)
whats a res?
its a new thermostat. and can it be the block is bad and ill need to replace it?
and whats a res?
Old Oct 4, 2008 | 06:37 PM
resiover
Old Oct 4, 2008 | 06:38 PM
vietnamezerice's Avatar
are you getting any mixture of coolant and oil?
Old Oct 4, 2008 | 06:49 PM
Default Re: GSR Overheating HEEEEELLLLLLLLPPPPP (vietnamezerice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">are you getting any mixture of coolant and oil?</TD></TR></TABLE>
how can you tell your oil is mixed with coolant?
Old Oct 4, 2008 | 07:00 PM
Fook_me_honda's Avatar
Pretty simple. oil will float on coolant so if there is any black oily substance in your coolant then well.....you get it right
Old Oct 4, 2008 | 08:03 PM
__oversea's Avatar
Default Re: GSR Overheating HEEEEELLLLLLLLPPPPP (Fook_me_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fook_me_honda &raquo;</TD></TR><TR><TD CLASS="quote">Pretty simple. oil will float on coolant so if there is any black oily substance in your coolant then well.....you get it right </TD></TR></TABLE>
in worst case milkyway.lol
it's possible damaged ports when they machined?
bleed the air.
with car running touch the upper and lower hose, if both hoses are warm(not hot), your thermostat is bad
Old Oct 5, 2008 | 12:22 PM
LOVEthatDC2's Avatar
was it all tq'd down right? 63 ft lbs on stock head bolts ... 80-85 on arp's ... i found out the hard way
oranginal
Mar 30, 2009 07:39 AM
Azn Batman
Nov 18, 2006 04:56 PM
blackeg
Sep 14, 2006 12:38 PM
Sam268
Mar 2, 2004 10:20 PM
hybridb18
Aug 6, 2003 09:00 PM
