need help, is this the main relay????
Old Oct 4, 2008 | 03:55 PM
90_EX_Civic's Avatar
Default need help, is this the main relay????
1. [IMG][/IMG]
2. [IMG][/IMG]
3. [IMG][/IMG]
okay, i know image #3 is a main relay(from my teg). now why the hell does number's 1 and 2 look so different???? aren't numbers 1 and 2 the main relay also??? oh, and 1 and 2 are the same relay just one with a out side pic and the other a inside pic, and it's from my EX.
and to add to the question of is the small one a main relay, is there a way to fix it???
Old Oct 4, 2008 | 04:04 PM
T2KU's Avatar
Is your car an auto??
I know on autos there is the main relay and another one that looks like those first 2 pics that is for the auto tranny
Old Oct 4, 2008 | 04:10 PM
Default Re: (T2KU)
really???? naw, it's a 90 ex 5speed.
when everyone says that it's your main relay, they say that's it's under your dash right about your hood release. well, that what i found under my dash for the civic. then i tried to google it, and they say that it might be ether a starter relay or a ignition relay. so it kinda throw me for a loop when in another thread they were talking about just re soldering some of the solder welds and it's all fixed. now i go and open the civic's relay and find what would be pic #2
Old Oct 4, 2008 | 04:17 PM
Default Re: (90_EX_Civic)
anyone else??? dogg, toad??? anyone???
Old Oct 4, 2008 | 04:33 PM
mr3sgte's Avatar
Default Re: need help, is this the main relay???? (90_EX_Civic)
The main relay on my '90 civic si looks like number 3, I have no idea what the first two are.
Old Oct 4, 2008 | 05:02 PM
honda.lioness's Avatar
Google for denso and the numbers on the side and see if it comes up on a parts site. Replicate the numbers on the side, and I will give it more of a shot.
Old Oct 4, 2008 | 05:06 PM
josh352727's Avatar
Default Re: need help, is this the main relay???? (honda.lioness)
Thats not the main relay (starter mayber), main relay is bigger. Kinda hidden but you will find it.
Old Oct 4, 2008 | 08:17 PM
T2KU's Avatar
to further answer your question...
the main relay will look just like the 3rd pic
look for your hood latch then get down in the driver's side floor and look a little above it to the right and it should be right there with one 10mm bolt in it
Old Oct 4, 2008 | 10:09 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (T2KU)
that is for sure your starter relay in pics 1 and 2. the teg and civic main relays look exactly the same.. so number 3 is what you will see by following the directions below.
the main relay can be located by finding the starter relay, then by following the bracket up the dash to where the whole thing attaches to a bolt going front to back. If you then look in the same space, there is a bolt going left to right. That bolt holds the bracket for the main relay. you will be able to see it if you look under there with a flashlight. Good luck, because it is the most pain in the *** bolt on the whole car, imho..
Old Oct 5, 2008 | 08:58 AM
Default Re: (sanimalp)
okay, thanks guys. it was just weird cause were i found number 1&2 is were i found the main relay for the teg, ???? go figure. but thanks guys.
Old Oct 5, 2008 | 09:00 AM
oh, almost forgot, is there a way to fix number 1&2???? im guessing not from the way it looks.
scorpiontank
Jul 20, 2007 01:21 PM
JDN169
Mar 28, 2007 07:06 PM
ProricanEF
Mar 28, 2007 01:16 PM
spoolinegsr
Oct 8, 2006 05:17 PM
90civicturboed
Jul 29, 2005 08:47 PM
