05' V6 Code error Navi/Radio
I have a 2005 Accord V6 with Navigation, XM radio, and 6 disk changer. I had to take the battery out inorder to replace a low beam bulb on the driver side which has reset all of my settings. I was able to input the code for the navigation but I still can't play any CD's or listen to the radio. When I turn on the power button, on the dash where it would normally show the time ect it's asking for a code which I contacted my dealership and they gave me a 5 digit code. Here is my problem, I don't have any preset buttons because it has to be accessed through the navigation when you hit the audio button on the lright side but that doesn't work. Numbers pop up on the dash when I use the tune button and it only allows me to enter 4 digits. Can anyone help me figure this out?
Anida
Modified by ANiDA at 6:14 PM 10/4/2008
Anida
easy
you need both codes, one for navi, one for radio
press power button, or tuning button, then turn it left or right to change the numbers and push it in to select the number and it will go to the next slot after a beep, and then repeat entering all radio code numbers
then on navi, just enter the navi code through the touch screen
doesn't matter which one you do first
mamidedos79
Mar 22, 2019 03:27 PM
