Need Some Idea's of what could be Wrong???
I just got my Build done and its only putting down 187whp and the compression is reading 210 across the board! Ok so here is what I got:
B18c5 Block
Stock ITR Crank
Eagle Rods
Wiseco 11:5 pistons Over sized .25
OEM Head gastet
Block gaurd
Clutch masters Lightened Flywheel
Clutch masters Clutch kit
B18C5 Head
Ferrea Valves Over sized 1mm
Supertech Valve springs/ret
Toda B Cams
Stock ITR Intake manifold/TB
Hondata IM Gasket
Precision 440 injectors
Toda header
Now Like I said its only making 187WHP on a mustang dyno. Im worried about the compression numbers really. I think it should be higher?? I dropped a Valve and had the head Fixed at a Machine shop and a light PNP done. The Block was also bored/decked/honed. Let me know what you guys think it could be?? thanks
B18c5 Block
Stock ITR Crank
Eagle Rods
OEM Head gastet
Block gaurd
B18C5 Head
Toda B Cams
Hondata IM Gasket
Toda header
you have a pretty good setup for street car....what program are you on???? To see more power with the setup you have....there's something you missing....just follow the rainbow and you will find a ported head awaiting for you......
Modified by DC2ALLMOTOR at 9:43 PM 10/4/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chanDAman562 »</TD></TR><TR><TD CLASS="quote">who build your motor?</TD></TR></TABLE>
I Dont want to put anybody on blast!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2ALLMOTOR »</TD></TR><TR><TD CLASS="quote">you have a pretty good setup for street car....what program are you on???? To see more power with the setup you have....there's something you missing....just follow the rainbow and you will find a ported head awaiting for you......
Im running Chrome.
Modified by DC2ALLMOTOR at 9:43 PM 10/4/2008</TD></TR></TABLE>
Im running Chrome.
I am guessing you wanted to break 200. You have a very solid set-up there are a few items that could help a bit.
The Toda header is good header but there are better ones out there; SMSP, Hytech with a full 2-1/2" or larger exhaust should give you some more.
Was the intake manifold port matched to the head? A larger bore Throttle body.
What kind of Intake? A 3" with a velocity stack is also a very good choice.
Just a few items for you think about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ev-Rnoob »</TD></TR><TR><TD CLASS="quote">I just got my Build done and its only putting down 187whp and the compression is reading 210 across the board! Ok so here is what I got:
B18c5 Block
Stock ITR Crank
Eagle Rods
OEM Head gastet
Block gaurd
B18C5 Head
Toda B Cams
Hondata IM Gasket
Toda header
Now Like I said its only making 187WHP on a mustang dyno. Im worried about the compression numbers really. I think it should be higher?? I dropped a Valve and had the head Fixed at a Machine shop and a light PNP done. The Block was also bored/decked/honed. Let me know what you guys think it could be?? thanks</TD></TR></TABLE>
your answer is, its a mustang dyno....which read.. the lowest, you want 200whp go to a dynojet.
On another note.. whats your exhaust..Toda header is ok.. but if u want real power i'd suggest smsp, bisimoto , or hytech.
You should have at least a 2.5''+ Exhaust and a good true 3'' intake with some type of vstack on the end..This is just a few things that come to mind..but you'll make 200whp on a dynojet..
B18c5 Block
Stock ITR Crank
Eagle Rods
OEM Head gastet
Block gaurd
B18C5 Head
Toda B Cams
Hondata IM Gasket
Toda header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R »</TD></TR><TR><TD CLASS="quote">
You should have at least a 2.5''+ Exhaust and a good true 3'' intake with some type of vstack on the end..This is just a few things that come to mind..but you'll make 200whp on a dynojet..</TD></TR></TABLE>
Im Running the Apexi WSP2!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_1fstgsr »</TD></TR><TR><TD CLASS="quote">I am guessing you wanted to break 200. You have a very solid set-up there are a few items that could help a bit.
Stock intake manifold/TB. Not port matched!
i would be happy if i was you. sounds like a strong motor. people dont realize toda specializes in road coarse stuff,so there concerned about mid range power not top end. post up your graph,i bet you have a nice midrange. if you want drag racing/topend power go with another cam/header combo
Stock intake manifold/TB. Not port matched! </TD></TR></TABLE> You got 187 on an Apexi, you should be REAL happy. Numbers now sound high.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> You got 187 on an Apexi, you should be REAL happy.</TD></TR></TABLE>
x2
x2
I'm in the same boat. My ITR only put down 186whp and 123wtq
3" SRI with BPI Velocity Stack
Hytech Header
T1R Exhaust
Supertech Flat Faced Valves, Dual Valve Springs, Stem Seals, Bronze Valve Guides
OEM Retainers
Skunk2 Stage 2 Cams
Skunk2 Cam Gears
Factory Overbored Pistons +.25
Cometic HeadGasket
Hondata IMG
I was expecting to break 200whp.
Compression ran 225 ACROSS. Did a leakdown and I have 20% leak in cylinder 1 and 4, rings are toast. Having it fixed in 2 weeks though.
PS: I blow smoke like crazy
Hytech Header
T1R Exhaust
OEM Retainers
Skunk2 Stage 2 Cams
Skunk2 Cam Gears
Cometic HeadGasket
Hondata IMG
One other little Problem is the Vtec doesnt Crack anymore. It just rolls into it?? Im not familar with these cams so any info will help. And im still thinking the compression is a little low 210 across the board??
Modified by 4ev-Rnoob at 4:00 PM 10/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ev-Rnoob »</TD></TR><TR><TD CLASS="quote">One other little Problem is the Vtec doesnt Crack anymore.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">
am I missing something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">yep, it's not supposed to "crack" once it's tuned. It should be a smooth transition.</TD></TR></TABLE>
Ok Thanks
One problem solved
Ok Thanks
One problem solved
itr_dreamer
May 3, 2006 11:21 AM
JerseySiPOS
Dec 8, 2004 01:53 PM
