Vtec Wiring d16z6
Old Oct 4, 2008 | 09:18 AM
TravisCadello's Avatar
Default Vtec Wiring d16z6
yea i have a d16z6 but the vtec sylonoid is not wired up and i cannot find any wires coming from the P26 ecu wire harness. is there a custom way i could wire the vtec to the distributor harness. please help!!!
Old Oct 4, 2008 | 09:29 AM
BlackoutVTi's Avatar
Default Re: Vtec Wiring d16z6 (TravisCadello)
You need to pin it yourself. A4 in the p28 is VTEC Solenoid. D6 is the Pressure switch. Second pin on the switch's plug goes to ground. Here's some more info.
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 ORN/WHT VTS VTEC solenoid
A5 LT BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/YEL FLR1 fuel pump
A8 (empty)
A9 GRN/WHT IACV IAC valve
A10 (empty)
A11 (empty)
A12 YEL/GRN FANC Fan Output
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/YEL ALT C alternator
A17
A18 (empty)
A19 (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to gound for o
A26 BRN/BLK LG1 gound
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 BRN/RED PSPSW PSP switch
B9 BLU/WHT clutch interlock switch
B10 YEL/BLU VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN SCS service check connector
D5 (empty)
D6 ORN/BLU VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 PNK ALT F alternator
D10 GRN/RED ELD electric load detector
D11 RED/BLU TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT PHO2S O2 sensor
D15 RED/YEL IAT IAT sensor
D16 WHT/YEL VREF VREF
D17 WHT MAP Map Signal
D18 (a/t trans only)
D19 YEL/GRN VCC1 MAP 5V
D20 YEL/WHT VCC2 TPS 5V
D21 GRN/BLU SG1 MAP GND
D22 GRN/WHT SG2 TPS GND
Old Oct 4, 2008 | 10:47 AM
Default Re: Vtec Wiring d16z6 (BlackoutVTi)
well its the orignal motor for the car. i bought it like this. shouldn't their be wires already their?
Old Oct 4, 2008 | 11:21 AM
Check the proper pins if you haven't already, and track them back from the ECU if you find them. If not, proceed to wire them.
Old Oct 4, 2008 | 11:35 AM
riceburnerryan's Avatar
hope that helps too
[IMG]
[/IMG]
Old Oct 4, 2008 | 04:08 PM
redlinexd's Avatar
im dont know much about ecu's but can u still use the ecu from a d16z6 and wire it to a b16?
Old Oct 4, 2008 | 04:10 PM
labtec2's Avatar
Default Re: (redlinexd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinexd &raquo;</TD></TR><TR><TD CLASS="quote">im dont know much about ecu's but can u still use the ecu from a d16z6 and wire it to a b16?</TD></TR></TABLE>
with an obd converter harness yes you can
Old Oct 6, 2008 | 07:10 AM
Default Re: (labtec2)
My brother some how wired up a toggle switch for his v-tec and told me theirs a huge diffrence in upper rpms. but thinking bout it i don't know how the hell a toggle switch works, cuz its supposed to be controlled by the dam ecu. but he says its working.
Old Oct 6, 2008 | 07:45 AM
94EG8's Avatar
Seagull Management
Default Re: (TravisCadello)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">My brother some how wired up a toggle switch for his v-tec and told me theirs a huge diffrence in upper rpms. but thinking bout it i don't know how the hell a toggle switch works, cuz its supposed to be controlled by the dam ecu. but he says its working.</TD></TR></TABLE>
It will sound like it working, but its not. high lift cam profile can be made to engage with a switch, but the fuel and timing maps wont change so you wont see any performance increase.
Old Oct 8, 2008 | 08:40 AM
Default Re: (94EG8)
yea, he took me for a ride and i herd it but i didn't feel it.
Old Oct 8, 2008 | 08:45 AM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">yea, he took me for a ride and i herd it but i didn't feel it.</TD></TR></TABLE>
dude its a single cam...you cant feel vtec in a sohc. lol unfortunately.
and op...here this might help. idk what trim yours is but this might be it.
http://rywire.com/store/9295-c...05ac5
Old Oct 28, 2008 | 07:20 PM
s1ngleslam's Avatar
quick question.. i have the same issue xcept mine is a cx.. i already wired the pressure switch and the silenoid and u say that the second pin on the connector of the switch is ground.. my question is this.. do i need to have a third wire to get ground or do i only have to wire up a4 and d6 in order for my vtec to ingage?? thanx in advance for the help.
Old Oct 28, 2008 | 07:23 PM
94EG8's Avatar
Seagull Management
Default Re: Vtec Wiring d16z6 (s1ngleslam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s1ngleslam &raquo;</TD></TR><TR><TD CLASS="quote">quick question.. i have the same issue xcept mine is a cx.. i already wired the pressure switch and the silenoid and u say that the second pin on the connector of the switch is ground.. my question is this.. do i need to have a third wire to get ground or do i only have to wire up a4 and d6 in order for my vtec to ingage?? thanx in advance for the help.</TD></TR></TABLE>
you need to wire a ground as well, you can simply run a wire from the other terminal of the plug and ground it to the body of the vtec solenoid.
Old Oct 29, 2008 | 07:05 AM
Default Re: (slo_hatch)
so how would we know if V-Tec works if you can't feel it?
Old Oct 29, 2008 | 07:26 AM
My brother has his on a toggle switch and he turned it on the other day while it was idling and it turned off. and then other times he turns it on it lowers 200rpms. i told him its probably not good to do that while idling.
Old Oct 29, 2008 | 07:50 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">so how would we know if V-Tec works if you can't feel it?</TD></TR></TABLE>
You can hear the crossover, it will be very faint though unless you have an intake.
Ever see a V8 with a high lift cam? They don't idle well. Thats why honda came up with vtec.
Old Oct 29, 2008 | 07:53 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Very simply put ditch the toggle switch idea.
You need to run wires from the VTEC solenoid and VTEC pressure switch into the pin locations as pictured in that diagram riceburnerry posted.
Old Oct 29, 2008 | 07:57 AM
Default Re: (B18C5-EH2)
My brother thinks the dam toggle switch work and i tell him everytime I don't hear or feel any diffrence. because he turns it on at like 4000rpm and at 5500 he asks me do you feel it? its like normal and never changes tones. lol I tried telling him look at this diagram on here and connect it to the ecu but he thinks his toggle works. all hes doing is giving the v tec solenoid 12 volts. i dont know how that would do anything lol.
Old Oct 29, 2008 | 09:07 AM
s1ngleslam's Avatar
Default Re: Vtec Wiring d16z6 (94EG8)
ok thanx bro realy helped.
Old Oct 29, 2008 | 11:24 AM
iamthefollower's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisCadello &raquo;</TD></TR><TR><TD CLASS="quote">i cannot find any wires coming from the P26 ecu wire harness.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
you need to wire a ground as well, you can simply run a wire from the other terminal of the plug and ground it to the body of the vtec solenoid.</TD></TR></TABLE>
You mean p28 right?? And yeah the vtec will come in on a toggle switch, you'll feel it in a hatch, but not really in a coupe, it'll mess the solenoid up though, but it is better to have it coming in on the ECU because you'll have the fuel maps and timing and all that stuff working, its way better to have it on the ECU...
You don't have to run a ground wire, because the solenoid is already grounded to the head, I'm sure that's what you were meaning though. All you need is the Vtec pressure switch ran and the solenoid wired up to the Ecu..
Old Oct 29, 2008 | 11:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labtec2 &raquo;</TD></TR><TR><TD CLASS="quote">
with an obd converter harness yes you can</TD></TR></TABLE>
You don't have to have a conversion harness to run a p28 on a b16 if the swap is in an obd1 car, you just have to have it chipped so that it will run it.
bmayo3595
Jan 17, 2015 05:11 AM
Andyb22g
Mar 15, 2006 10:45 PM
2SlowDC
Oct 19, 2005 12:52 PM
lemongreenhatch
Jun 11, 2004 06:45 PM
-[95cxhatch]-
Sep 9, 2003 07:10 PM
