What should I do to the H22a block to run a forged piston?
Old Jul 27, 2002 | 02:19 PM
dvp95's Avatar
Default What should I do to the H22a block to run a forged piston?
I have a 98 JDM H22a and have heard that they have some nikasel sleeve. All I currently have is a 50hp shot and your basic bolt ons. I want to just get pistons and rods, but I dont know about this sleeving thing. Are there any pistons where you dont have to resleeve your block? I want to increase my nitrous shot but want to take care of this problem first.
Old Jul 27, 2002 | 03:59 PM
areyouasian's Avatar
Default Re: What should I do to the H22a block to run a forged piston? (dvp95)
Are you planning on raising or lowering your compression with these pistons? if you are raising compression then you can get h22a type s pistons. they run 11:1 and you wont have to resleeve with those. if you get forged pistons though then you will have to resleeve, cause in the long run its a lot better for the block.
Old Jul 27, 2002 | 04:21 PM
dvp95's Avatar
Default Re: What should I do to the H22a block to run a forged piston? (areyouasian)
well I was planning on getting a good strong piston so that I could run a higher shot of nitrous without raising or lowering the compression. Somewhere between a 10.0:1-11.0:1 would be fine. I would like an aftermarket piston though.
Thanks
Old Jul 27, 2002 | 06:07 PM
kevie88's Avatar
Why not a set of stock JDM 10.8:1 pistons?
Old Jul 27, 2002 | 06:35 PM
dvp95's Avatar
Default Re: What should I do to the H22a block to run a forged piston? (kevie88)
i already have JDM 10.6:1 pistons. How much can they hold?
Old Jul 29, 2002 | 05:50 PM
LordVtec's Avatar
I have a 5th gen type S, and i have been running 80 shot safetly for about 3years now... i have the basic bolt on's (exaust, intake, ignition system) stock feul system, and stock compression... i wouldnt reccomend pushing it passed 80 without upgrading your feul system.... if need any help or have any questions, let me know...
92_civic_lx
Dec 20, 2008 05:59 AM
hondabigblock
Dec 7, 2008 05:41 AM
speedyonez
Jun 28, 2005 11:20 PM
dvp95
Jul 27, 2002 07:27 PM
