B16 head problems
Old Oct 3, 2008 | 10:38 PM
vtec dub's Avatar
Default B16 head problems
Let me give u some back ground about what is done to the head. I had the casting flashes removed and polished a little bit. Jun spec 3 cams, skunk2 high lift double valve springs, Omni power hi-comp valves. And I skimmed a lot of the head to raise my CR.
My head surface is almost level with my skuice pad in my combustion chambers. I had to enlarge the inside of my valve guides as the stems of the omni power valves is a little bit larger.:help::help:
This is an allmotor build. No my valves are not touch pistons.
I just have this weird noise and I can not get it sorted.
I also have set the valve clearances to the right spec. Plse help
Old Oct 4, 2008 | 09:28 PM
vtec dub's Avatar
Default Re: B16 head problems (vtec dub)
Guys, anyone for a suggestion?
Old Oct 4, 2008 | 09:31 PM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec dub &raquo;</TD></TR><TR><TD CLASS="quote">Let me give u some back ground about what is done to the head. I had the casting flashes removed and polished a little bit. Jun spec 3 cams, skunk2 high lift double valve springs, Omni power hi-comp valves. And I skimmed a lot of the head to raise my CR.
I also have set the valve clearances to the right spec. Plse help</TD></TR></TABLE>
Explain.
Old Oct 4, 2008 | 10:11 PM
vtec dub's Avatar
Default Re: B16 head problems (downest)
In my language they call it RIEM. It is a delicate process to enlarge the hole to a specific size.
Old Oct 4, 2008 | 10:34 PM
downest's Avatar
I meant did you do it yourself or was it done by a machinist/specialist? Or, both, if you are one.
What is the noise it makes? My head makes a lot of noise with the skunk2 springs and large cams as well, hard to describe I guess, it made me nervous at first but everything is assembled correctly and lash has been checked and rechecked many times.
Old Oct 4, 2008 | 10:52 PM
vtec dub's Avatar
I have changed the springs with standard springs and the noise was still there.
It was done by a machinist.
Old Oct 4, 2008 | 10:55 PM
Combustion Contraption's Avatar
Default FV-QR
In this language its spelled REAM.
What kind of clearance was there before they opened them up?
Old Oct 5, 2008 | 12:00 AM
Fkned's Avatar
Default Re: FV-QR (Combustion Contraption)
I haven't used any omni valves,but I find it hard to believe they were tight enough to need the guides reamed and not just honed a tiny bit for the correct clearence.
Where they new guides or original,and were they honed properly after you reamed them?
What clearence do you have now do you know?
Old Oct 5, 2008 | 05:01 AM
IntegraType-R's Avatar
Does anyone else find this odd? I heard doing this was bad..
Old Oct 5, 2008 | 08:31 AM
DonF's Avatar
Default Re: B16 head problems (IntegraType-R)
What size(bore) are the pistons, and what deck height are they at?
baynedo
Mid-Atlantic (Sales)
May 27, 2011 01:55 PM
vtec dub
Oct 29, 2008 09:59 PM
1991b20bteg
Oct 10, 2008 02:34 PM
AntMan401
Mar 17, 2008 02:13 PM
^AnDre^
Dec 1, 2004 10:51 AM
