Do all ITR's make this noise? (not the dreaded clicking)
Old Jul 27, 2002 | 01:59 PM
Rwecked's Avatar
Default Do all ITR's make this noise? (not the dreaded clicking)
Got a 98 and just recently she started making a "clunking" sound. Sounds kinda like a sway bar endlink problem but they're fine. Replaced the bushings on the sway bar, noise still there. Makes the noise under braking and under change of momentum, sounds like it's coming from the firewall area. Are the Typies notoriously bad on engine mounts? I ordered one (rear) and it's on back order from the dealer. Am I being vague enough? Anyone got any ideas? Thanks
Old Jul 27, 2002 | 02:04 PM
underrated99si's Avatar
Default Re: Do all ITR's make this noise? (PackinThird)
had same prob on my car could not figure out what it was it ended up to be a motor mount sometimes they break but you can not see the problem on the outside I replaced my driverside and now no more clunk
Old Jul 28, 2002 | 07:38 AM
Rwecked's Avatar
Default Re: Do all ITR's make this noise? (underrated99si)
Thanks Bro. I had a feeling that was it. How did you know to start with that particular mount? I think mine sounds like the rear mount but I figure any of the mounts being worn will make some sort of noise. Just gotta check em out eh?
Old Jul 28, 2002 | 09:12 AM
uNF$@#!'s Avatar
yes, braking under pressure = "klunk"...check your motor mounts!
SIDreamer
11
Mar 1, 2011 05:25 AM
Evil-Mpire
18
Feb 17, 2010 12:59 PM
Stevegunit16
Jan 5, 2007 09:23 PM
Pnoyej6
Jul 14, 2006 07:31 PM
330R
Sep 9, 2002 07:58 PM
