GSR swap - no crank - blown battery fuse.
Old Oct 3, 2008 | 05:28 PM
Ldo's Avatar
Ldo
Default GSR swap - no crank - blown battery fuse.
Finally finished putting everything together and turned the key, no crank, battery fuse blown. I could hear the fuel pump and main relay working.
I know there's probably a billion causes, but any rough idea on where to begin?
Old Oct 3, 2008 | 05:59 PM
SovXietday's Avatar
Default Re: GSR swap - no crank - blown battery fuse. (Ldo)
You didn't flip your pos and neg terminals on the battery did you?
Old Oct 3, 2008 | 06:05 PM
Ldo's Avatar
Ldo
Default Re: GSR swap - no crank - blown battery fuse. (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">You didn't flip your pos and neg terminals on the battery did you? </TD></TR></TABLE>
That was the first thing I checked, but they are correct.
Old Oct 3, 2008 | 06:13 PM
grog's Avatar
i would begin with replacing the fuse, and hope it doesnt blow again, if it does its probably a wiring issue which could be anywhere.
mtg
Nov 29, 2009 07:44 AM
dc2teg2006
Mar 28, 2009 05:31 PM
rhd_ef8
12
Apr 29, 2007 11:27 AM
Mychal71
Sep 10, 2006 02:01 PM
