having big clutch problem
hey guys i need some help.i have a 90 ls/v wit a b16a trans. i installed my clutch yesterday its a stage 3 i got to put my tranny on try ou t the clutch and there is no pressure on my pedal i adjusted the cable blah blah the pedal moves the fork up and down getting stuck at the bottom but no pressure im also having a clearance problem with the fork the bottom of my clutch cable it hitting the tranny which is most likeley causeing it to get stuck but i was seeing if anybody had some suggestions i was tthink my clutch plate is backwords but if it was wouldnt the pressure plate not fit right and would that solve my clearance issue some guy was saying something about a retainer and the clutch only has 1/2 play i have no idea what he was saying but i didnt change my throwout bearing and i only feel pressure at about a half in off the floor help me out please
Wow, that was kinda hard to read...
But from the gist of it, it seems you arent feeling any resistance when you press the clutch in, correct? Sounds like something is wrong with the fork/throwout bearing on the inside of the tranny case. You either installed it wrong or something is not in place correctly.
I dont see how you can incorrectly install the clutch/pressure plate, assuming the input shaft fit into the clutch smooth - that's about all there is to it. FYI, it's the pressure plate that give you that resistance in the clutch pedal. So if you're not feeling any stiffness in your clutch pedal, the fork/throwout bearing is not doing it's job. Or there is too much slack with the cable. Either way, sounds like you need to retrace your steps and maybe even remove the tranny again to see what you did wrong.
Gary Albano
Apr 8, 2013 02:56 PM
