Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (56k no way!!)
Old Oct 3, 2008 | 10:48 AM
totsie7944's Avatar
Default Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (56k no way!!)
PICS of engine added!
Well the car has been running for about 4 months now, but I never got a chance to make a thread on the build. This was my first ever turbo build, first full (internal) motor build, first time pulling a motor, etc. It wasn't cheap by any means, but your only young once.
I need to shoot out a special thanks to:
Jeff Evans (www.evans-tuning.com) Great tuner, great advice, great guy. He has tuned my car for the third time now. Each time the car has made some of the highest numbers I've seen for what the car has had done to it. As well, I got consistently great gas mileage and reliability out of the car.
Jim Justice (justiceracingengines.com Got me the best parts out there in a timely fashion, built the motor to a "T". Kept me posted weekly on progress and was VERY patient in helping me after I picked up my motor to make sure I got everything together correctly. Was a great experience working with him
Tony from T1racedevelopment.com He answered a lot of questions before and after the build. Got me some great parts and worked with me to figure out of issues during the fab process. Great guy.
Terry from BoostFed.com ....he was a HUGE help, put up with ALOT of my bitching and definately took care of me when I was stressed, didn't understand something, or needed help...even after hours lol
Aaron from Full-race.com definately dealt with alot with my order, but got me the best parts out there and my #'s show it.
Stan the man from Fast-Turbo got me like 100 lines practically next day when I was in a huge rush
If I forgot anyone else I'm sorry, but THANK YOU!
Below you will find pics of where the car came from at its N/A build, the actual turbo build process, completion, dyno plot, parts in build, etc. The car is not done yet...I need to get some tires for the new wheels, do some tidying up here and there etc. I also plan on running the new Bosch 1000cc saturated injectors and some skunk 2 tuner 2 cams.
Where the car came from (2 of a kind custom Jenvey ITB's, Toda C Cams, Toda valve train, CTR pistons, RC 440 injectors, SMSP header, SMSP exhaust, Fidanza FW, ACT HDSS Clutch, etc)
Fidanza after 40+k miles
Clutch after 40+k miles
Jenvey ITB's
CTR pistons
Motor out of car before getting torn down on my back porch for building..
Car on jack stands....where it sat for 5 months....
Engine bay naked! (notice the red power cable..Battery re-route for T1 Catch can baby!)
Car at SMSP....Dave doing some exhaust work for me to get it lined up right!
Picking up the motor from Justice Racing!! So pretty
Motor in my basement while I re-assemble it. Head back on block, cams, valve train, etc.
Getting timing right...
THe night I put the motor back in the car!
Car complete and detailed!
New steering wheel and Wheels to go on car in the spring...(need tires)..PS I kept my horn with this wheel...if you'd like to keep it with a Sparco wheel I can help
DYNO PLOT
Don't pay attention to the upper charge pipes missing. I took them off to get powder coated and the intercooler anodized.
Oil Block
Build:
Full Race B-series Traction Bar
Full Race Front Mount 22x8x3 & Piping
Thermal 3” Exhaust
Full Race 3" Downpipe
Full Race Dump Tube
PWR Radiator and Full Race Fan
Full Race ProStreet AC Stage 3 GT Kit
Full Race Vacuum Block (2)
Intercooler Anodizing
Coatings for turbo, manifold, piping, etc
Oil Line/Vacuum Line/Hardware/Gasket/Hose Clamp/Silicon Coupler Kit
GT 35r Turbo .82 A/R Exhaust Housing
Tial 50mm BOV
Tial 44mm Wastegate w/ 8lb spring
Walbro 255lph HP Fuel Pump Intank
Competition Stage 5 clutch w/ upgraded pressure plate
Ultralightweight 7 lb Flywheel
RPM Services 72mm TB (w/o sensors)
Plug Wires NGK Blues
Greddy Timing Belt
Edelbrock Intake Manifold
AEM Fuel Rail
Aeromotive A1000 FPR
Tein Hood Dampers
Hasport Motor Mounts
RC 1000cc Injectors Peak and Hold
Justice Racing
Darton Sleeves 84mm bore x 89 mm stroke
ERL MID kit
9:1 CP Pistons
Manley Rods
Ferrera Valve Train w/ TI retainers, bronze valve guides
LS Crank
ITR Cams
T1 Catch Can
Omnipower 4-bar map sensor
Oil restrictor
Outlaw Engineering IM gasket
Autometer (Wideband, Boost, Oil Temp, Oil Pressure, Fuel Pressure, Wire Temp & Press)
Sparco Wheel/Hub/Bolt-On Quick Release #Civic/CRX 92-95
Battery re-route kit
A-SpecRacing 32mm rear sway bar
Samco Radiator Hoses
TPS sensor from King
Portflow P&P Head
Neptune (Jeff Evans)
ARP Studs & bolts (Main, Head, clutch & flywheel bolts)
Toda Cam Gears
Volk TE37 +35 (Black)
Thanks for looking. Motor pics coming this weekend...
Modified by totsie7944 at 5:50 PM 10/5/2008
Old Oct 3, 2008 | 12:05 PM
Turbocivic94's Avatar
Default Re: Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (totsie7944)
nice setup
Old Oct 3, 2008 | 12:33 PM
totsie7944's Avatar
Default Re: Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (Turbocivic94)
Thanks man
Old Oct 3, 2008 | 03:15 PM
Minor Threat's Avatar
How much boost?
91 Octane?
Car must be a rocketship!
Silva Bullit DC4's Avatar
Wow thats and awesome build with awesome numbers, you got any vids of the dyno runs? I wanna hear this evil thing sing!
Old Oct 3, 2008 | 04:03 PM
Cole D's Avatar
your setup is my dream very nice
Old Oct 3, 2008 | 04:34 PM
cvcrtonv's Avatar
How do you like the cc clutch with the upgraded pressure plate?
Old Oct 3, 2008 | 05:02 PM
23hatchturbo's Avatar
Default Re: (cvcrtonv)
Nice choice of wheels i want a set nice build
Old Oct 3, 2008 | 05:25 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">**COMPLETED ENGINE BAY PICS TO BE ADDED TOMORROW!!**
Volk TE37 +35 (Black)...
unless this is a strict drag track only car having fun in the rain an every day driving the thicker your rear sway bar the closer you get to the effect of a solid axle. you're going to get alot of oversteer. how is the rest of the suspension set-up ?
Old Oct 3, 2008 | 06:31 PM
ghostofnyc's Avatar
nice
Old Oct 3, 2008 | 06:44 PM
totsie7944's Avatar
Default Re: Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (Minor Threat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Minor Threat &raquo;</TD></TR><TR><TD CLASS="quote">How much boost?
91 Octane?
Car must be a rocketship!</TD></TR></TABLE>
21 psi made 540 whp 19 psi made 507. Its def a fun ride man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silva Bullit DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Wow thats and awesome build with awesome numbers, you got any vids of the dyno runs? I wanna hear this evil thing sing! </TD></TR></TABLE>
Haha I actually never got a video of it on the dyno, but I'm going to re-tune in the early spring/late winter with different cams and injectors.
WHen I do, I'll shoot some video.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvcrtonv &raquo;</TD></TR><TR><TD CLASS="quote">How do you like the cc clutch with the upgraded pressure plate?</TD></TR></TABLE>
Its great man, no complaints at all. Was a little harsh at first but then you get used to it. Now that its a bit more broken in I have no issues cruising around with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
unless this is a strict drag track only car having fun in the rain an every day driving the thicker your rear sway bar the closer you get to the effect of a solid axle. you're going to get alot of oversteer. how is the rest of the suspension set-up ? </TD></TR></TABLE>
I don't DD the car....but I was and am well aware of the effects of a sway bar thanks...if it couldn't be used, they wouldn't make it.....However, the ride is nice. I plan on doing a PIC coilover build, function 7 lca's, bushings, etc come winter of 2009. I add something every fall and spring. This spring is cams, customlightz HID's, and tires for the wheels.
Old Oct 3, 2008 | 06:50 PM
prelude2perfect's Avatar
Default Re: Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (tony413)
"unless this is a strict drag track only car having fun in the rain an every day driving &lt;IMG NAME="icon" SRC="https://honda-tech.com/forums/images/smilies/emthdown.gif" BORDER="0"&gt; the thicker your rear sway bar the closer you get to the effect of a solid axle. you're going to get alot of oversteer. how is the rest of the suspension set-up ? "
I don't own a type r but I know with my 98 prelude a stiff rear sway bar is the way to go since it has a lot of understeer. the sway bar gives it more neutral handling experience. ^Do you even drive a front wheel drive honda?
to the op, sweet setup man!
Old Oct 3, 2008 | 07:53 PM
96 GSR-T's Avatar
Very sick man, I bought an 00 ITR brand new and totaled it 6 months later, I always had dreams to build her up to the level you built yours too.
I will be switching to Tuner 2's in the spring too and heading back up to Jeff for a re-tune, cant wait.....
Old Oct 3, 2008 | 09:50 PM
Redcoupe's Avatar
Default Re: (96 GSR-T)
PM'd you man about your motor build. I had a couple questions I didn't want to ask on here.
Very nice setup though.
And really really nice R.
Old Oct 3, 2008 | 10:34 PM
tony413's Avatar
ok cool thats good to know this is not a street car . as for the rest of your suspension the PIC select sound like a good choice for DRAG racing, if the car was used for anything else then koni and custom ground control all the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude2perfect &raquo;</TD></TR><TR><TD CLASS="quote">
!</TD></TR></TABLE>
when you learn about the wheelbase, springrate, and curb weight of the prelude compared to an EG/DC chassis then post back a vaild response until then "Do you even drive a front wheel drive honda?" also have you driven a civic or integra with a 32mm rear sway bar ? i have to say its a strictly race track only piece.
Old Oct 4, 2008 | 06:37 AM
R.A.T.'s Avatar
Very nice! Beautiful build and nice dyno chart.
What the guy above me is saying about the sway bar, the 32mm is dangerous on the street. Just be careful with it. It causes alot of oversteer, I've heard so many stories of integras spinning out on the street because of a thick bar. Anyways, it's up to you.
Now go put those rims on and take pictures! I want to see how sick it looks!
Old Oct 4, 2008 | 08:53 AM
totsie7944's Avatar
The PIC suspension was purposely designed with HPDE's and handling in mind...not sure where you heard it was for drag racing? I'd be more apt to putting Koni's on for dragging honestly. However I am not dead set on PIC right now...its another year away before I mess with it...I might do something Tein related. We'll see, not sure where I will be by then lol
Old Oct 4, 2008 | 09:14 AM
tony413's Avatar
The PIC suspension was purposely designed with HPDE's and handling in mind...not sure where you heard it was for drag racing? I'd be more apt to putting Koni's on for dragging honestly. However I am not dead set on PIC right now...its another year away before I mess with it...I might do something Tein related. We'll see, not sure where I will be by then lol</TD></TR></TABLE>
i think you too may need to go study up a bit. im saying you should use the PIC rear drag coilovers here http://picperformance.com/stor...t=194
you do know that the usual street koni is alot SOFTER than a PIC select right ?
pic uses kg/mm measurements and koni uses lb/in. most people running konis on the street have rates of 8kg/mm NOT 10kg/mm and 12kg/mm like PIC. so while the PIC brand is good for road race circuits they are awesome for drag racing as well, you want a stiff car and koni DOESNT offer that for the SAME price as PIC
Old Oct 4, 2008 | 12:00 PM
B20luda's Avatar
Finished engine bay pictures looks good otherwise
Old Oct 4, 2008 | 04:44 PM
TheShodan's Avatar
Moderator
I'm in the same bind b/w the PIC-Swift combo and the TEIN REs like my other GS-R build. I have to admit a 3rd choice would be the Skunk 2 Pro series stuff as well.
After dealing with Koni's for years in 2003-2006, I gave up on them due to the damn perches breaking. I just wasn't satisfied with them. I could see them on a MacPherson system like the RSX and EP3, but not on a double-wishbone setup like civic/integra/TSX.
Old Oct 4, 2008 | 04:50 PM
tony413's Avatar
Default Re: Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
After dealing with Koni's for years in 2003-2006, I gave up on them due to the damn perches breaking. I just wasn't satisfied with them. I could see them on a MacPherson system like the RSX and EP3, but not on a double-wishbone setup like civic/integra/TSX.</TD></TR></TABLE>
please tell me you were not using koni's for drag racing they are too soft unless you get custom rates around 750lb/in or higher.
rear springrates for a drag car should be 800lb/in to 1000lb/in but thats my personally pref, because its reduces rear squating the best
Old Oct 4, 2008 | 06:04 PM
DC4KiD's Avatar
that thing must fly.
Full Race
Old Oct 5, 2008 | 02:45 AM
phil-jdm's Avatar
Amazing number.
Old Oct 5, 2008 | 11:29 AM
Cole D's Avatar
Default Re: Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (Cole D)
You double your horsepower from 4500 to 5500; 5500 to 6500 you gain 100hp 6500 to 7500 another 100hp that thing must pull like a freight train GOOD JOB
Old Oct 5, 2008 | 11:47 AM
tech7427's Avatar
youre just so cool tootsie. lol
ill see you again at the hyper meet soon buddy. i was the guy with mattyp in the yellow s2k..
lookin good man..hopefully ill have the s2k done by the time we see each other next ;-)
