Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need help with B series cable GSR tranny
Old Oct 3, 2008 | 03:02 AM
90lsvcrxva's Avatar
Default Need help with B series cable GSR tranny
Ok guys just had two trannys given to me. One is a Gsr cable vtec will only go into 3 and 4th gear? Other one is a cable LS and has a bad sycnro I believe (thats what I was told) Are some of the parts interchangable? Any ideas whats wrong with the GSR? I would really like to use that gsr trans!!!!! Please let me know Ima crack open housing this weekend and see if there is anything that sticks out!
Old Oct 3, 2008 | 02:38 PM
Aquafina's Avatar
Tear the GSR down and find out why it won't go into other gears. First thoughts are you will definitely not like the cost of parts to fix it.
Old Oct 8, 2008 | 07:09 AM
hondateg08's Avatar
Depends on what type of Ls tranny you got. If it is a ysi LS tranny than it is interchangeable with the GSR ysi tranny, if the transmission is from the older 90-91 integra such as the S1 then it won't work.
Old Oct 10, 2008 | 09:07 PM
civickiller's Avatar
Default Re: (hondateg08)
syncro ring might be bent, fixing a tranny right now, wouldnt go into 3rd. that little ring bent up bad. could be the slider or whatever its called that puts it into gear. take it apart and find out
projecthybrid04
Aug 9, 2009 02:05 AM
91EF919
May 13, 2009 07:30 PM
jc2801
Jan 16, 2009 04:58 PM
acurar0ss
Feb 16, 2004 11:08 PM
schtozo
Feb 21, 2003 11:48 AM
