Suspension & Brakes Theory, alignment, spring rates....
I NEED HELP CLICK ON TOPIC (Integra brake issue)
Old Oct 2, 2008 | 07:57 PM
Jdm integra DB8's Avatar
Default BRAKE PROBLEM (CLICK ON TOPIC):wave:
Alright guys are are the specs
1995 Acura integra 4dr (Four doors for life)
Brand New Rotor Both sides
Brand New Pads Both sides
Brand New Caliper Only the left side
Here is the problem i get a mean shake when i press my brakes around 60mph+ only on the highway. On the local roads no shake. I see soo much brake dust on my left rims only and it smells like brake dust and the right side is fine no brake dust or anything help.
Modified by Jdm integra DB8 at 6:18 PM 10/3/2008
Modified by Jdm integra DB8 at 6:19 PM 10/3/2008
Old Oct 3, 2008 | 07:05 AM
hatchling37's Avatar
Default Re: I NEED HELP CLICK ON TOPIC (Jdm integra DB8)
You should replace calipers in pairs. Is it pulling when you brake? You should probably take the right side apart and clean and lubricate the slide pins.
Old Oct 3, 2008 | 05:21 PM
Default Re: I NEED HELP CLICK ON TOPIC (hatchling37)
I did and it still does it today i jack the car and the driver side wheel was hard to rotate and the passenger side i can turn it easliy
Old Oct 3, 2008 | 05:37 PM
Targa250R's Avatar
be professional
Default Re: BRAKE PROBLEM (CLICK ON TOPIC):wave: (Jdm integra DB8)
The caliper you installed may either be faulty, wrong, or incorrectly installed.
Since I highly doubt you bought a brand new caliper, I'm going to assume it's remanufactured. What brand remanufactured it and where did you buy it? Did it come preloaded with pad springs and clips, and were the slide pins adequately greased? What pads did you install? Did they go in easily and do they move freely in the caliper bracket? Sometimes pad backing plates can be slightly out of spec, causing the pads to stick in the brackets.
It is also possible that the right caliper which you didn't replace is faulty, causing the opposite side to bear the full braking load; this will create an abnormal amount of heat and wear on the working side. Check for a stuck piston (replace or rebuild) or dry/seized slide pins (lube them).
If you're getting a high speed shimmy now, you may have already created uneven friction material deposits on the new rotors, which may or may not be curable with an aggressive pad bedding session. If not, you will probably have to have the rotors turned on a brake lathe, or you could try exchanging them if the retailer has a good warranty/return policy.
Also, why did you do a brake job? Were you having problems prior to this, or were the parts just worn to their service limits?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">You should replace calipers in pairs.</TD></TR></TABLE>
Not true at all.
Old Oct 3, 2008 | 05:41 PM
Targa250R's Avatar
be professional
Default Re: BRAKE PROBLEM (Targa250R)
I also took the liberty of editing your thread title to actually include a reference to the problem.
Old Oct 3, 2008 | 05:54 PM
Its a remanufactured cailper brought it from advance auto
It came with slides and everything and i grease the slide pins with cailper lube
The pads i don't know the name but i but them from advance auto brand new
and the pads move freely from the bracket
And a tip today i jack up the car and the driver side was hard to turn but the passenger side i can turn with my finger and the driver side has brake dust all over the rim too.
Old Oct 3, 2008 | 06:09 PM
Targa250R's Avatar
be professional
Default Re: BRAKE PROBLEM (Jdm integra DB8)
You're going to have to take the wheel off and inspect the left front brake to figure out what is happening. The piston or the slide pins in the new caliper may be stuck.
civiceagle2
Mar 11, 2013 06:49 AM
-iLLuZioN-B18C1
Oct 12, 2008 02:45 PM
Frank_2.0L
May 31, 2006 10:25 PM
LOwrestling2001
Apr 7, 2003 08:47 PM
