My car stinks
Old Oct 2, 2008 | 01:24 PM
sixgunsound's Avatar
Default My car stinks
I have a 1990 CRX Si with a DOHC ZC swap. The car reaks of exhaust/gas inside and outside. If I drive across town my clothes will smell like it. I dont know if maybe its overfueling or something but has anyone else experienced this or know what it could be?
Old Oct 2, 2008 | 03:41 PM
alscrx's Avatar
Default Re: My car stinks (sixgunsound)
maybe your charcoal canister is bad! Check it....its on the firewall. It collects vapors so it could be bador clogged now
Old Oct 2, 2008 | 04:06 PM
beana's Avatar
you probably have a fuel leak either under the hood or in the car ,i'm guessing the gasket around the door for the fuel pump has a crack in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">maybe your charcoal canister is bad! Check it....its on the firewall. It collects vapors so it could be bador clogged now </TD></TR></TABLE>
dude...if the charcoal canister is clogged it would run like sh*t
and if it was coming from the exhaust (which the canister would do) you would't make it across town with out passing out from the CO
Old Oct 2, 2008 | 04:17 PM
Default Re: My car stinks (beana)
Yah it dosent run like **** so its not the charcoal canister. I suppose it could be a fuel leak since I'm also getting shitty gas mileage. I'l look into that, thanks
Old Oct 2, 2008 | 05:01 PM
Zish06's Avatar
mine was doin the same i replaced my fuel filter and problem was solved.
Old Oct 2, 2008 | 06:38 PM
Default Re: My car stinks (Zish06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zish06 &raquo;</TD></TR><TR><TD CLASS="quote">mine was doin the same i replaced my fuel filter and problem was solved.</TD></TR></TABLE>
Also a solid suggestion. Thanks man.
Old Oct 2, 2008 | 07:13 PM
HOODLOVER's Avatar
make sure you keep your window down so you dont pass out
alscrx
10
Dec 22, 2007 07:06 PM
ryyo
16
May 15, 2007 04:19 PM
Silvteg95
Dec 12, 2005 01:13 PM
90SICRX
May 20, 2004 03:34 PM
hadehatch
Apr 20, 2004 09:44 PM
