soft clutch pedal
Old Oct 2, 2008 | 11:54 AM
Wazup's Avatar
Default soft clutch pedal
When pushing in the clutch, the pedal firmness is really soft. I'm used to hydraulic clutches, so i was wondering what could cause this in a cable clutch? Could it just be that the clutch is worn?
Or can it be adjusted via the cable?
Old Oct 2, 2008 | 12:00 PM
sgallagher's Avatar
Default Re: soft clutch pedal (Wazup)
It can be adjusted via the cable. the adjustment is almost at the end of the cable at the release fork for the throwout bearing. You can adjust the grab point of the clutch. Be careful not to tighten too much or you will be engaging the pressure plate causing slipping and premature wear.
89hatcher's Avatar
is it a stock clutch and pressure plate?
Old Oct 2, 2008 | 12:13 PM
Wazup's Avatar
Default Re: (89hatcher)
yes, all stock
what tools, if any, would i need to use to adjust it?
Old Oct 6, 2008 | 08:15 PM
sgallagher's Avatar
Default Re: (Wazup)
no tools necessary.
Old Oct 6, 2008 | 08:37 PM
91civiccross's Avatar
Default Re: (sgallagher)
Keep in mind that no matter how much you adjust it, it wont get any stiffer.
Cable trannies are known for the soft peddle.
There should be a small bit of play in the arm. I believe around 1/8" or around there. Check a manual for the play.
the_augie
Jul 19, 2015 03:16 PM
xTimmyx
Dec 10, 2011 05:57 AM
Radim
Feb 19, 2010 11:15 AM
clemsonteg
Mar 11, 2006 07:10 PM
GooD moToRs
Jun 27, 2003 02:33 AM
