short throw shifters stright vs single vs dual bend
Whats the difference between the straight, single and dual bend short shifters? Just how close the shift **** is to the steering wheel?
any opinions on brands?
Modified by luciffer at 5:05 PM 10/2/2008
I’m using a Fastline Road Race dual bend shifter in a ‘91 CRX. I’m 5’10” tall so I also use a 75mm (2.95 in) steering wheel spacer. The dual bend shifter allows the gearshift to be closer to the steering wheel. Shifts throws are the same as stock, but shifting to 5th gear feels longer than stock. I also had to cut the shift linkage counter weight below the car to clear my larger aftermarket Invidia exhaust. Also, it started to get a little rust on it, so I coated it with rust converter.
You can read more about it below:
http://www.fastlineperformance.com/shifter.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe »</TD></TR><TR><TD CLASS="quote">IMO i would grab a dual bend from a gsr
NO ebay special ones , just straight OEM GSR</TD></TR></TABLE>
x2, but I like my S2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20eg6hatch »</TD></TR><TR><TD CLASS="quote">You will never feel anything smoother than when the S2 dual bend and the S2 shift **** are combined. I love mine</TD></TR></TABLE>
X2..I love mine as well....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsi89 »</TD></TR><TR><TD CLASS="quote">i have a s2 dual bend in my crx and i would have to say my only complaint would be the half a mile reach for 5th.</TD></TR></TABLE>
Thats not the shifter. Thats ALL the shifters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luciffer »</TD></TR><TR><TD CLASS="quote">Whats the difference between the straight, single and dual bend short shifters? Just how close the shift **** is to the steering wheel?
any opinions on brands?</TD></TR></TABLE>
The FLP is probably the only one that puts you closer to the wheel. The others just move teh shifter closer or further front to back, more or less.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa »</TD></TR><TR><TD CLASS="quote">I have the B&M single bend SS, and I like it. Excuse the dirtyness. This is with a GSR ****:
does that gsr **** screw on like a factory shift ****?
</TD></TR></TABLE>does that gsr **** screw on like a factory shift ****?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfereorhatch »</TD></TR><TR><TD CLASS="quote">
does that gsr **** screw on like a factory shift ****?</TD></TR></TABLE>
Yes it does.
Yes it does.
</TD></TR></TABLE>Does the gsr have a shorter throw over a stock ef version?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker »</TD></TR><TR><TD CLASS="quote">Short shifters are bad for your tranny. </TD></TR></TABLE>
what?? NOT true. speed shifting may be bad for your tranny, but changing the throw on the linkage does nothing to the internals. you are simply making less work for yourself. plenty of people ruin transmissions with stock shifters
Short shifters won't mess up your tranny. Don't try to slam gears before engaging the clutch.
Rev match, you can shift into gears without using the clutch. (I did it all the time in my Integra without grinding) If you know your car well, RPM, GEAR, you can do this without grinding.
The Integra im talking about, (97 LS with I/H/E, ran a 15.4 with full interior, P/S, and A/C. I used the clutch, but only to shift into the gear. (I didn't use it when I pulled out of gear.)
