tps sensor wiring?
how do you mean wired wrong? The only thing I could think you would do would be to swap the map sensor connector and the tps sensor connector. The MAP sensor plug should have a White wire, Green with White Stripe and Yellow with a Red stripe. The other plug would be your TPS sensor.
