timing belt cover
Old Oct 1, 2008 | 08:17 PM
95_red_dc's Avatar
Default timing belt cover
I bought a obd-2 oil pump for my obd-1 b18c1. I was told that to get the timing belt cover to fit you would need to trim it a little bit. I'm pretty sure you have to modify it at the bottom of the cover but not to sure. Can anyone inform me on this tell where about I need to trim it.
Old Oct 2, 2008 | 02:04 PM
95_red_dc's Avatar
Default Re: timing belt cover (95_red_dc)
bump I know someone done this before
Old Oct 2, 2008 | 05:04 PM
berb_15's Avatar
I'm not sure that there's any difference. I have my timing belt cover from my b18b1 on my b18a block with a type R oil pump which is a pretty good mix up, but I can't be 100% sure
Old Oct 2, 2008 | 05:40 PM
kronikSLOW's Avatar
Default Re: timing belt cover (berb_15)
why dont you put the pump in. line the cover up and see where you need to trim its not rocket science its a plastic cover. dont mean to jump on you but get real.
Old Oct 2, 2008 | 06:23 PM
berb_15's Avatar
Default Re: timing belt cover (kronikSLOW)
wow dude calm down it was a question some people don't like to hack all their stuff up, it's called keeping it clean
Old Oct 3, 2008 | 08:25 AM
kronikSLOW's Avatar
well yes it will be clean and not all hacked up if you take the time to look at what has been layed right in front of your eyes.
Old Oct 3, 2008 | 08:28 AM
SuzukaBlueAP2's Avatar
the covers should be identical for 94-01 engines.
nowayintegra14
Dec 2, 2010 02:21 PM
blackdude
Jan 25, 2006 07:39 PM
jefe
Aug 15, 2004 08:11 PM
85mm LS VTEC
Aug 4, 2004 02:18 PM
