Suspension & Brakes Theory, alignment, spring rates....
Cheapest place to get brakes bled?
Old Oct 1, 2008 | 02:28 PM
Allurian's Avatar
Default Cheapest place to get brakes bled?
I recently replaced my master cylinder with a reman. master cylinder and got the brakes bled at pepboys for $60... well the reman. master was faulty and started leaking again. I plan on replacing the master cylinder w/ a brand new cylinder and having a shop just bleed my brakes for me but dont want to spend $60 again if I can find it cheaper. Is there any shop that is cheaper... I'm currently in Raleigh, NC. Any help appreciated
Old Oct 1, 2008 | 02:39 PM
SmellsLikeMustand's Avatar
Default Re: Cheapest place to get brakes bled? (Allurian)
bench bleed then bleed ur brakes. 30 min if ur know wtf ur doing.
Old Oct 1, 2008 | 04:00 PM
Richard123vmt's Avatar
Default Re: Cheapest place to get brakes bled? (SmellsLikeMustand)
Ditto to Smellslike.... No need to spend $60 for brake bleeding ever. If assistance is a problem get a bleeder valve kit (can also be made of out a simple vacuum valve) for a few dollars. This allows you to work alone. I have replaced a master cyclinder (not on a Honda but a VW bus) and did without bench bleeding--muddled through somehow and five years later all is well.
Old Oct 1, 2008 | 04:28 PM
Allurian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmellsLikeMustand &raquo;</TD></TR><TR><TD CLASS="quote">bench bleed then bleed ur brakes. 30 min if ur know wtf ur doing. </TD></TR></TABLE>
I know how to bench bleed i.e. I replaced the master cylinder myslef, just don't have time to bleed brake system as well any time soon
Old Oct 1, 2008 | 05:13 PM
dcblackbird's Avatar
you have time to install a master cylinder but no time to bleed brakes?
Old Oct 1, 2008 | 05:28 PM
Allurian's Avatar
Default Re: Cheapest place to get brakes bled? (dcblackbird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcblackbird &raquo;</TD></TR><TR><TD CLASS="quote">you have time to install a master cylinder but no time to bleed brakes?</TD></TR></TABLE>
Obviously you haven't installed a master cylinder before, It takes two minutes tops once you bench bleed the cylinder...all it is is two bolts to the booster and the two brake lines... GTFO if you have nothing to add to the thread noob
Old Oct 1, 2008 | 07:13 PM
opera936's Avatar
lol i'll do it for $20
But seriously if you can still brake, wait until you have time to do it yourself. Bc IMHO it is really not worth the $$ to pay some guy $60 to do something that you can do yourself. I have been driving on my Ek hatch withOUT proper bleeding the lines after the rear disc swap for an year. If you really have to get it done by someone else, anything above $80 I'll say its not worth it.
Old Oct 1, 2008 | 11:17 PM
JDM_DC4_Fanatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allurian &raquo;</TD></TR><TR><TD CLASS="quote">
Obviously you haven't installed a master cylinder before, It takes two minutes tops once you bench bleed the cylinder...all it is is two bolts to the booster and the two brake lines... GTFO if you have nothing to add to the thread noob</TD></TR></TABLE>
honestly, if you have time 2 drop the car off to have i fixed, just do it yourself. plus, you wont be stopping if you change the master but don't bleed the lines.
if you insist on aking it to a shop, try offering cash, it may get the work done for cheap.
Old Oct 1, 2008 | 11:30 PM
60 bucks is cheap for getting the brakes bled.
on a lift..
Old Oct 2, 2008 | 05:16 AM
Allurian's Avatar
Default Re: Cheapest place to get brakes bled? (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
if you insist on aking it to a shop, try offering cash, it may get the work done for cheap.</TD></TR></TABLE>
Last time I changed it in the parking lot of pepboys so I didn't have to drive anywhere, but all advice is appreciated
Old Oct 2, 2008 | 07:41 PM
nonsense's Avatar
buy speed bleeders and DIY in about 15 minutes. It's easy.
bretx0r
20
Jan 21, 2015 04:59 PM
efsex
Aug 19, 2010 02:34 AM
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
y49crxsi
Jul 16, 2004 02:14 PM
miataguy
Jul 8, 2003 09:00 PM
