what would cause hesitation when on the gas?
Old Jul 27, 2002 | 08:55 AM
BoM's Avatar
BoM
Default what would cause hesitation when on the gas?
it stutters when when the u press the gas pedal
then the car just goes.
vaccuum leaks were checked and okay! no leaks
what else could it bee?
Old Jul 27, 2002 | 09:36 AM
Malgerus's Avatar
Default Re: what would cause hesitation when on the gas? (BoM)
check timing, could be bad fuel pump, bad dizzy, or ignition components. Try the fuel filter too.
Old Jul 27, 2002 | 05:49 PM
IN VTEC's Avatar
Misfires. Ignition or fuel. I experienced a problem like this on my brother's Talon an eon ago. It was the spark plug wires. Check the resistance.
Limit is 25k ohms max @ a temperature of 68 degrees F. If any one of them is higher than that, replace them all.
I've even got a spare set from my '95 GS-R that you can have if they fit.
Old Jul 27, 2002 | 09:36 PM
EGh22aEG's Avatar
Default Re: what would cause hesitation when on the gas? (IN VTEC)
the plug wires are new
Old Jul 27, 2002 | 11:55 PM
MikeSarr_GSR's Avatar
Default Re: what would cause hesitation when on the gas? (esp169)
bad TPS sensor
bobbyjr
Nov 20, 2007 07:05 PM
d4rksid3
Feb 22, 2007 12:45 AM
flyguy0086
Jan 23, 2007 10:11 PM
All Motor EH2
Mar 4, 2005 05:55 PM
4bidden
Nov 28, 2002 08:52 PM
