Suspension & Brakes Theory, alignment, spring rates....
Suspension 4 door vs 2 door SI
Old Oct 1, 2008 | 12:03 PM
^AnDre^'s Avatar
Default Suspension 4 door vs 2 door SI
Are there any suspension differences between the 4 door and 2 door si or are they same?
I have a 4 door SI shell and now looking for a donor car for the suspension components. Can I pickup a 2 door SI and have everything bolt up or do I need to specifically look at 4 doors?
Old Oct 1, 2008 | 01:02 PM
alphalanos's Avatar
Default Re: Suspension 4 door vs 2 door SI (^AnDre^)
I assume youre talking about the new Civics, this belongs in a different forum.
Old Oct 2, 2008 | 01:59 PM
Targa250R's Avatar
be professional
What year?
Old Oct 2, 2008 | 06:39 PM
batallic's Avatar
what year, the new ones 4 doors have mac struts all around, 2dr si has wishbone in rear
Old Oct 2, 2008 | 07:43 PM
Targa250R's Avatar
be professional
Default Re: (batallic)
Okay, I just spent some time snooping through the parts catalog to compare '06-08 Civic Si 2dr and Si 4dr. With exception of the springs, dampers, and front sway bar (including FSB bushings), the entire suspensions are exactly the same.
This includes all of the control arms, end links, brackets, knuckles, bushings, ball joints, bump stops, upper damper mounts, the rear sway bar, and the front subframe.
I'm convinced that the springs and front sway bar are compatible as well, and only different in specification rather than fitment. Not sure on the dampers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic &raquo;</TD></TR><TR><TD CLASS="quote">what year, the new ones 4 doors have mac struts all around, 2dr si has wishbone in rear</TD></TR></TABLE>
That is incorrect on both counts.
'06+ Civic coupe and sedan both have McPherson struts up front and a double wishbone-emulating multilink rear suspension.
agent420
Apr 8, 2013 08:02 PM
^AnDre^
Honda Civic (2006 - 2015)
Oct 2, 2008 12:48 PM
fongyz22
Honda Civic (2001 - 2005)
Jan 31, 2008 01:47 PM
02civic_rida
Dec 14, 2007 04:56 PM
