Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Wheel Bearings on a 1998 4WD CR-V
Old Oct 1, 2008 | 06:45 AM
Dahmer's Avatar
Default Wheel Bearings on a 1998 4WD CR-V
Alright so a while back I noticed I had a rubbing/grinding noise in the Driver front wheel well. so after some diagnosis by myself and a few shops we had realised that the cracked coil (which has been cracked since I bought the CR-V) had been dislodged and was rubbing against my strut.
so I got new coils in the front. and... now the sound is WORSE! I get a constant grinding noise after about 60km/h but the stranger part is that it gets louder when I accelerate! I spent all last night looking at manuals and how-to videos about a possible bearing replacement? am I barking up the wrong tree?
someone mentioned that this was a mechanics only job because the bearings had to be machined off and all that. has anyone done this before? is it terribly expensive?
Old Oct 1, 2008 | 01:55 PM
motion's Avatar
The old bearing would have to be pressed out by a machine, with the new bearing pressed in. You can do most of the work yourself by removing the hub and bringing it to a shop.
fuzzysig
Suspension & Brakes
Aug 25, 2017 12:17 PM
chris d
Suspension & Brakes
Aug 29, 2016 02:04 PM
EyePhoto
11
Sep 19, 2013 02:21 PM
CivicVX94
Oct 15, 2007 05:42 PM
ViZ
Feb 11, 2005 07:52 PM
