Suspension & Brakes Theory, alignment, spring rates....
Removing ABS pump from my 95 gsr?
Old Oct 1, 2008 | 06:02 AM
twentyhurtz's Avatar
Default Removing ABS pump from my 95 gsr?
hi, i have a 95 gsr, with the big abs pump. Since i bought the car it has been throwing abs code 2, my code sheet says thats abs pump motor, so i found another abs unit for about 60 bux, swapped it, the old one was blowing fuses, this one doesn't, actually comes on for a minute, but once i get to about 10 mph, the light comes back on, and throws the same code. Does anyone know what this could be? also i have a brake line splitter that mounted on the firewall of a 95 civic hatch, can i just remove my unit, mount that on my firewall, and re run my lines to it and have non ABS brakes? Would anything else have to change? Should i just fix the current problem have keep ABS brakes?
Old Oct 5, 2008 | 06:43 PM
racebum's Avatar
Default Re: Removing ABS pump from my 95 gsr? (twentyhurtz)
test the wheel sensors for resistance, check all connections. if that isn't it your ebcm is likely dead. many cars throw up some weird *** codes when the abs computer dies. if your pump is known good, those are the only two things left.
trevee
Jul 28, 2011 09:00 PM
billdrah
Sep 26, 2009 11:47 AM
Marcg611
Sep 19, 2009 01:14 PM
redDC2
Nov 4, 2002 04:02 PM
