92 Accord Cruise Control Issue
Old Oct 1, 2008 | 05:37 AM
jonwrong's Avatar
Default 92 Accord Cruise Control Issue
Well, my cruise control does not work, and I have been trying to troubleshoot this issue for some time. The button to the left of the steering column does not light up when turned on, and of course, the cruise does not work. I have check the fuse under the dash, I have swapped the vacuum servo, and I have tried a new cruise control ECU. I have done everything short of rewiring it. Does anyone have any similar experience or ideas apart from jsut checking wires with a multi-meter? Thanks in advance!
Old Oct 1, 2008 | 07:18 AM
E.Honda's Avatar
Default Re: 92 Accord Cruise Control Issue (jonwrong)
If you need any parts let me know...I am parting out a 91 accord Se.
Old Oct 1, 2008 | 11:23 AM
Big_Eddy's Avatar
Two areas to look.
The main relay under the dash - see the FAQ's - can also affect the Cruise - mine did.
Second - check your brake (and clutch) switches - In my car - on cold mornings the brake switch is not made when the brake is released and the Cruise will not engage until I "lift" the pedal with my toe. I need to get under there and adjust the positioning slightly.
My button does not light up -- not sure it is supposed to. Should be easy to check for power before and after the switch though.
Old Oct 1, 2008 | 04:02 PM
hondadude's Avatar
Maybe this diagnostic chart will help, but I seem to think that if the light at the switch isn't turning on when the button is pressed you will need to find out why it isn't getting power.
Old Oct 2, 2008 | 04:57 AM
jonwrong's Avatar
THANKS! I was not sure if the light on the switch lights or not. I will try to troubleshoot it this way. I am also trying to hunt down the entire system relay to see if that is worth a shot.
Old Oct 3, 2008 | 01:27 PM
JONESER's Avatar
Default Re: (jonwrong)
I have a 91 and my cruise button lights up when it's on.
meals
May 8, 2014 07:21 AM
cocjace
Feb 23, 2010 01:37 AM
nwn4772
Apr 19, 2007 03:21 PM
commoncents100
Mar 4, 2007 04:24 PM
