piston to wall with rs machines pistons?
my motor is at the machine shop, and i cant find the manufacturer recommended piston to wall tolerances for my 84.5mm itr pistons. is there one or should i use stock specs condsidering they are cast aluminum like the stock ones?
It depends if you are seeing track time (road racing) with sessions as long as 40 mins then you will need more clearance. I would not go above 1.8 thou. That will give you the ability to take more heat due to extended runs, but you will have more wear and a little less life.
my motor will be daily driven, through nice weather and snowstorms. i might track it a few times, but mostly be driven around 3000-6000 rpms. should i go a little on the smaller side???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anti-Drama Queens »</TD></TR><TR><TD CLASS="quote">i PMed rsmachines about his pistons and he recommended .0015...84.5mm as well</TD></TR></TABLE>
thats what i was looking for. rock on, and thanks to everyone for the advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
thats what i was looking for. rock on, and thanks to everyone for the advice</TD></TR></TABLE>
GL with your build.
GL with your build.
prostreetonline
Jun 24, 2004 09:02 PM
mz3bo
Jun 18, 2004 06:34 PM
turbo Si
Jun 28, 2002 12:00 PM
