Changine valve seals: Do i really need compressed air?
I really really want to change my valve seals because i dont like pouring in a quart a week. The only thing holding me back is acquiring a air compressor. I was wondering if i can just crank the motor manually so that the cylinder i'm working with is at TDC. If it's at TDC the valve shouldn't drop for that cylinder right?
air gun to put valve springs back on? are you serious? you know the valve is held onto the retainer by keepers.. there's no air gun involved in that. i use to use a bench vise to compress the springs and use zip ties to hold them compressed and install the retainer and slip the keepers in.. and cut the zip ties.. dangerous yes i know but hey if you know what you're doing then its not..
Where does anyone say anything about an air gun?You fill the cyl with air so it holds the valves up when you want to remove/replace the springs/seals.
I've dissasembled hunderds of heads in the shop and most times the keepers are so locked into the retainer it needs to be tapped with a small hammer to dislodge them.
All I can say is that I'd rather have the air hold the valve when I'm depressing the retainer to remove the keepers then it smacking the piston top.
take some soft cotton rope, tie a knot in one end, and take the other end and feed a bunch of it into the cylinder, slowly crank the engine by hand till the rope is pushed up against the valves. You can now pull the springs and seals. When done lower the piston, pull the rope out, and go to the next one. I've done this at the strip where we didn't have a compresser.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ClassicConcepts »</TD></TR><TR><TD CLASS="quote">take some soft cotton rope, tie a knot in one end, and take the other end and feed a bunch of it into the cylinder, slowly crank the engine by hand till the rope is pushed up against the valves. You can now pull the springs and seals. When done lower the piston, pull the rope out, and go to the next one. I've done this at the strip where we didn't have a compresser.</TD></TR></TABLE>yes this works well if not alot riskier then air.
Noboby had an air tank at the track for their tires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned »</TD></TR><TR><TD CLASS="quote">yes this works well if not alot riskier then air.
Noboby had an air tank at the track for their tires?</TD></TR></TABLE> He is going to be pissed after all that work and now only uses .95 of a Quart a week.
150 miles? i drive at least 400 a week and yeah its about a quart. if not less. i dont know how much a quart raises the level on the dipstick, so my guess is a quart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K i l l a B e e. »</TD></TR><TR><TD CLASS="quote">150 miles? i drive at least 400 a week and yeah its about a quart. if not less. i dont know how much a quart raises the level on the dipstick, so my guess is a quart.</TD></TR></TABLE>Oh it's 400 miles please forgive my mistake.
Dude you just don't get it,seals arent going to leak a qt even if you drove 1000mi a week.
The fact that it burns at high rpm doesn't tell you something?
the easy and simple way is to do a cylinder leak down test on all the cylinders and it will show where the problem is. i would be betting the rings are the major issue at hand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned »</TD></TR><TR><TD CLASS="quote">Oh it's 400 miles please forgive my mistake.
dude, im not retarded.. burning oil at high rpm doesnt necessarily mean rings.... Like i said., the compression numbers come out good on all cylinders. i added oil too and the compression numbers remained the same.
Ok
I guess Don doesn't know what he's talking about either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> He is going to be pissed after all that work and now only uses .95 of a Quart a week.</TD></TR></TABLE>
You can have good consistent compression and have shitty oil control...... what causes this?!?!? I'll give you a hint.... they are on the pistons and control oil.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil M »</TD></TR><TR><TD CLASS="quote">
You can have good consistent compression and have shitty oil control...... what causes this?!?!? I'll give you a hint.... they are on the pistons and control oil.....</TD></TR></TABLE>What you mean there are rings other then the top one???????
