Konis with GC...limited travel?
Well I about got the motor wrapped up and now I am feeling I wanna dump these Omnis and get a Koni/ Ground Control setup. I really have gotten spoiled with the limited travel on these cheap coil overs. I wish they had a little more rebound travel. I have done some searching and found some answers and info, but I thought I would try to be more direct than I found
So are all three Sports, SP3, and their Race shocks limited rebound travel? I just wanna see or know where these would sit extended.
I hope I am referring everything in the correct terms... correct me if need be
Modified by badboyr66 at 3:56 AM 10/1/2008
8041-Sports have the same droop travel as stock when used with stock upper mounts.
8041-SP3 have 20mm of additional droop limiter material inside the body, so they have 20mm less droop travel than stock or regular Sports.
8041-RACE have both shortened bodies (25mm front and 15mm rear) and additional droop limiter material (40mm front and 35mm rear) compared to the regular Sports. I do not recommend that these be used with Ground Control upper mounts, as you will be constantly topping out the dampers.
Yeah man thank you for the info.....
Where to get them?... Thats easy... cruise over to the Vendor Suspension area... or search "koni ground control" Support your HT Sponsor
"todays secret word is "droop"
93SIRII
Feb 7, 2009 06:45 PM
doubleshotz
Suspension & Brakes
21
Oct 5, 2007 02:55 PM
racekar711
Suspension & Brakes
Dec 2, 2005 08:30 PM
nc-rsx-s
Oct 9, 2002 11:52 AM
