Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07' SI Throttle Lag.
Old Sep 30, 2008 | 11:12 PM
knaira112387's Avatar
Default 07' SI Throttle Lag.
Okay so sometimes when i have the clutch depressed partially and try to rev the rpms does not go up with the gas pedal down for about a half second. For example when i push on the gas the rpms would probably slightly jump but not as if you were in neutral trying to rev the rpms up. im guessing this is the downfall of electronic throttle for our cars?
Old Oct 1, 2008 | 10:03 AM
FA5civicSI's Avatar
Default Re: 07' SI Throttle Lag. (knaira112387)
i have the exact same problem with my 08
Old Oct 1, 2008 | 11:27 AM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Drive by wire FTL
Basically when you push the gas pedal, the signal is sent to your cars computer and then it calculates what to do.
Vs pushing the gas and the wire automatically starting the acceleration.
100miles+'s Avatar
Default Re: 07' SI Throttle Lag. (100miles+)
I hear the p2R throttle body spacer gets rid of throttle lag, but I never had a chance to put mine on.
Old Oct 1, 2008 | 11:51 AM
eh. my tbs wont fit with the damn intake.
Old Oct 1, 2008 | 11:52 AM
i gotta figure out what i wanna do with the bracket thats holding the harness. if i wanna bent it or just break it off.. but then again i dont wanna do that to my car ;p
Old Oct 2, 2008 | 08:10 AM
25RFG2's Avatar
Default Re: (knaira112387)
What intake do you have? I just put my TB spacer with gaskets and IMG and I noticed a little difference. Found a local shop to convert my DBW to cable and use Kpro for a little under 2000.
Old Oct 2, 2008 | 08:24 AM
IT GUY's Avatar
Default Re: (25RFG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25RFG2 &raquo;</TD></TR><TR><TD CLASS="quote">What intake do you have? I just put my TB spacer with gaskets and IMG and I noticed a little difference. Found a local shop to convert my DBW to cable and use Kpro for a little under 2000.</TD></TR></TABLE>
pics? how'd you get the dash to work?
Old Oct 2, 2008 | 11:01 AM
08JDMsi's Avatar
Im having the same problem. You can convert it to cable throttle instead of electronic ( my buddy did this ) and it works amazing. Im soon to be doing it to mine! Look into that
Old Oct 2, 2008 | 12:46 PM
i-VTEC_DOHC's Avatar
heres a solution to your throttle lag.
air conditioning
also the conversion is possible. i read that u can just hard wire the speedo to the vss like the older hondas. but u need to modify the wiring
Old Oct 3, 2008 | 10:46 AM
25RFG2's Avatar
Default Re: (IT GUY)
Have not done the conversion yet......... still trying to decide.
Old Oct 3, 2008 | 02:09 PM
i dont know about doing that to a 20k car and doing any hack of the wiring of any sort since its still brand new. its too extensive as it is..
Old Oct 3, 2008 | 02:11 PM
i have injen intake.. the filter itself sits on the harness bracket. its snug i cant even twist the intake to make it avoid it.. i just might have to bend it or something.
Old Oct 4, 2008 | 04:01 PM
08JDMsi's Avatar
With the whole throttle thing, i hear that they making a kpro for our cars ( and not just using the one from the rsx type s ) THEY ARE making a solution for the lag. I was reading in some article so i would hold off for a little more. Other wise your looking to spend 2k or so.
Old Oct 4, 2008 | 04:37 PM
yesterday when i was reversing my rpms jumped up by itself right when the fan turned on i was like WTFFFFFFFFFF
Old Oct 4, 2008 | 04:38 PM
it jumped up to like 6k too.
Old Oct 4, 2008 | 05:07 PM
FijiBlueFG2's Avatar
Road House
Sometimes mine will rev on it's own up to about 1.3k-1.5k rpms, but never 6k.
Old Oct 4, 2008 | 09:34 PM
HONDA_RACER92's Avatar
The lagg has to be the most stupid thing they have ever programmed into a car. With that said, it was programmed in for ecconomy in mind so I've been told by the Honda Tech I work with. In a performance vehicle thats pretty stupid. Mine to has done everthing you guys have mentioned here and I can't stand it. But, Take a look on Buddy Clubs site there is something new that will let you dial out the lag and make the throttle snappy.{NO Lag or some Lag} It's not on the market as of yet but is comming very soon. Also, King Motorsports did mention to me at their Dyno Days a month ago that the Kpro is done but for some reason Hondata doesn't want to release it yet. Don't have a clue why.
http://www.buddyclub.us/buddyc....html
Modified by HONDA_RACER92 at 12:56 AM 10/5/2008
Old Oct 5, 2008 | 08:31 AM
25RFG2's Avatar
Default Re: (HONDA_RACER92)
Well I hope its true........ The only reason I was going to convert was for KPRO.
Old Oct 5, 2008 | 06:46 PM
To pricey and no technology DBW
Old Oct 5, 2008 | 10:06 PM
sageuvagony's Avatar
My 1991 Ford Explorer did that exact same thing. You could SLAM the gas pedal to the floor, but there will be that 1/2 second before ANYTHING happens.
Old Oct 13, 2008 | 09:39 AM
Default Re: (sageuvagony)
SLoppy linkage on the carb. LOL!!!!!!
Old Oct 14, 2008 | 06:03 PM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">My 1991 Ford Explorer did that exact same thing. You could SLAM the gas pedal to the floor, but there will be that 1/2 second before ANYTHING happens.</TD></TR></TABLE>
This has everything to do with the words FORD, EXPLORER and PIG lol
Old Oct 14, 2008 | 10:04 PM
vladd's Avatar
Default Re: (i-VTEC_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">heres a solution to your throttle lag.
air conditioning
also the conversion is possible. i read that u can just hard wire the speedo to the vss like the older hondas. but u need to modify the wiring</TD></TR></TABLE>
the speedo has nothing to do with the rev hang.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 08JDMsi &raquo;</TD></TR><TR><TD CLASS="quote">With the whole throttle thing, i hear that they making a kpro for our cars ( and not just using the one from the rsx type s ) THEY ARE making a solution for the lag. I was reading in some article so i would hold off for a little more. Other wise your looking to spend 2k or so.</TD></TR></TABLE>
from what i've heard hondata said that they're not going to modify the dbw system for liability reasons, so the coming of kpro won't do anything for the hang issue.
Old Oct 17, 2008 | 11:58 AM
gotone4ya's Avatar
i am looking into a Blitz throttle controller that they originally made for WRX's and Evo's. and i hear that Buddy Club has a similar controller avail. WAY less $$ than kpro too.
Applications:
  • Lexus GS350 2006+ / IS350 2005+
  • Toyota Yaris 2006+
  • Scion tC 2004+ / xB 2008+
  • Nissan Altima 2007+ / 350Z 2003-2006 / Versa 2007+
  • Infiniti G37 2008 / G35 2003-2006
  • Subaru Impreza STi 2004-2007 / WRX 2008 / STi 2008
  • Mitsubishi Evo X 2008
  • <FONT COLOR=""Yellow"">Honda Civic Si 2006+</FONT>
