1990 Honda Crx Parts and swap For Sale/ Best Offer Must Go!!!
Old Sep 30, 2008 | 06:45 PM
crxb16d2's Avatar
Default 1990 Honda Crx Parts and swap For Sale/ Best Offer Must Go!!!
1990 Honda Crx Stock Parts for Sale.
I am cleaning out these parts since I no longer have the car. If you are interested just make an offer on the parts you need. No shipping only pickup.
Email me at Danemesls@aol.com
Pictures of the parts are on this myspace website.
Click pictures and they are under the stock parts album.
http://profile.myspace.com/ind...08396
Engine Body Mechanical parts. For Sale Motor Swap
Stock original 1990 CRX HF motor, Shift linkage mounts Everything included. (Some bolts, all belts as well)
Transmission ( L3-2070605), Clutch, Motor Engine Block( D15B6, 3301651) PGM-FI, Alternator, Garage Kept, could get at a junkyard (some wire harness some used for the motor swap) Belts included .Motor has 80 thousand on it. Transmission was rebuilt, and barely used for a short period of time after that because the motor was swapped out.
Passed inspection, had no check engine lights or oil leaks, the cat converter and header in the headers included and still on motor. and computer comes with it.
Trying to sell it all together as opposed to parts buy email me if you need something specific, I will keep you offer in mind if I part it out.
Receipt of vehicle passed inspection comes with motor, and transmission receipt included or transmission work done as well.
Left and right front HF Knuckles( Good condition)
Left and right HF Rear Knuckles Drum Brakes ( Good condition)
Threads on knuckles are perfect. Bearing are good, and brakes are also good, ebrake cables good.
Crx master cylinder that functioned properly with proportioning valve.
HF Springs and shocks: good condition still together as one piece.
Crx radiator, ac and engine cooling fan: perfect working condition, cap included, changed out because bottom antifreeze flange did not match new motor swap flange on motor.
Crx AC components.
Stock HF Air Intake System,
Rear wiper and motor with harness:
Crx hf front bumper reinforcement.
Bottom passenger sideskirt plastic /clips included.
Two red Fenders Used have some dents. Two origional red crx fenders.
Spare Passenger Side Headlight has small chip on glass gets moisture inside, still functional for damaged headlight. (spare bulbs I may have included.)
HF Steering Wheel with center cap.
Crx Passenger Seat with brackets.
Driver side seat brackets.
One 4 lug crx steel rim with tire. ( Pirelli P400 touring, size 175/70R13)
Two spare 195-55-15 Khumo 711 Ecsta treads allmost gone but they still hold air, use for track burnouts ... sell rims w tires
Heater climate temperature switch.
Ebrake rubber cover/ ebrake hardware.
Plastic pieces shown for molding outside of car, and fender.
Blinker assembly lights on and off, handle broke can be epoxies, or just switch part used if you have the handle.
Back trunk brakets., plastic.
Passenger side mirror broken, moves properly.
Side mirrow covering plastic. When you have no mirror.
After market resonator to quiet vehicle exhaust.
1990 JDM B16A Motor Swap parts left over.
1988-1991 (XSi) OBD-0 B16 require both vtec solenoid gaskets from a 91 Acura NSX. (Genuine Honda Parts.)
Smaller Upper Gasket: #36172-PR3-005 Selling brand new in bag
Large gasket: #15825-PR3-005 (used, no ripped screen perfect, use with rtv blue seals like new.)
Large gasket Civic SI Thickert: #15825-P08-005 (used, not ripped screen slightly dented, use with rtv seals like new.) Never used because it was wrong gasket for obdo motor.
Used B16 valve cover gasket. And 4 Spark plug Gaskets.
Use with rtv won’t leak, quick fix for burnt out gaskets, without. Still in good shape
B16 Power Steering components and brackets.
B16 air intake plastic connected to throttle body.
B16 half shaft, axle front
Old Oct 11, 2008 | 08:23 PM
socalibur's Avatar
Default Re: 1990 Honda Crx Parts and swap For Sale/ Best Offer Must Go!!! (crxb16d2)
pm'ed
GoneToTheDarkSide
Jun 25, 2009 02:59 PM
whiteef-8
Oct 18, 2004 10:22 PM
spoolin92
Nov 24, 2003 04:16 PM
