K20 K series B series Turbo, lots of stuff for sale to buy house
PRICES UPDATED AND OBO
Here is a list of parts I have for sale:
TURBO STUFF:
30"x12"x3" intercooler, new only mounted----------$130
Tial 44mm WG... purple and silver----------------- $290 each
NEW OBX 50mm BOV silver--------------------------$150
Aeromotive FPR----------------------------------------$120
BOSCH 044 fuel pump, brand new never used only installed-$225
Precision 1000cc injectors-----------------------------$250
Innovate Wideband LC-1 and XD-1 gauge (needs O2 sensor)-------$225
<U> K-SERIES STUFF</U>
NEW Wiseco 86mm and Eagle rod combo-$730
NEW K- series Wavetrac LSD---------------------$900
type S throttle body with sensors--------$160
Civic SI K series 5 speed trans------------$600
NEW K-tuned AC & PS removal kit ----$160
Type S head with all valvetrain but not installed- $700
Sparkks racing conversion harness--------------$250
K20a2 crank GOOD-------------------------------$250
Type R cams------------------------------------$275
Type S alternator------------------------------$150
03 k20a2 engine harness-----------------------$250
NEW Competition clutch stage 2---------------$350
04 Type S fuse box---------------------------- $50
K-series K20a2 type S flywheel- RESURFACED----------$70
K20a2 stock header---------------------------------------- $10
K20a2 power steering pump -------------------------------$40
ALPHAWERKS DC2 integra catback exhaust-----------$300 OBO
<U>B-SERIES STUFF</U>
LS CAMS, B18B1---------------------------$25
94-01 Integra radiator------------$60
LS tapped oil pan -10AN welded on-------$40
resistor box with pigtail -------------------$30
Integra lower tranny mount--------------$30
ALL SENSORS OFF obd2 ls motor.... make offer for each, iac, etc... have them all...
OBD2 Ls intake-------------------------- $30
ALL SWAP MOUNTS, $100 for set, includes, ac bracket, lower tranny mount, driver side mount, tranny mount, rear t-bracket, and rear mount.
OBD2 ls valve cover--------------------$40
OBD1 LS valve cover------------------ $20
Integra rear t-bracket----------------- $30
Stock b-series fuel rail---------------- $20
EG hatch side skirts------------------- $25
LS obd1 engine harness--------------- $75
B-series flywheel---------------------- $20
B-series shift linkage------------------ $40
B-series half shaft---------------------- $40
Integra driver side mount------------- $20
Bseries stock clutch line, goes from firewall to tranny $15
EK condensor ---------------------------$10
LEGIT LS longblock. Needs rebuild.--- $200
obd2 b-series manual starter---------- $40
obd2 b-series power steering pump ---$30
obd2 b-series alternator ----------------$40
obd2 ls ecu ------------------------------$75
part of DC2 that is under the tail lights that goes across back of car above bumper, perfecto condition, -----------$60
92-95 hatch rear bumper, black OEM, 6 out of 10 condition on paint, $25
Collector is a T3 divided. It is twin scroll and has flange welded. Bought these pieces from Straight Line Specialties for $80 unwelded and i welded it up but no need for it------------------------ $75
EBC Rotors NEW IN BOX drilled/slotted zinc anodized, found here for $123.11, the cheapest place on the net. Sold in pairs. Perfect for upgrading your stock brake rotors. $90 OBO
Will fit:
Honda Civic 1.5 DX Coupe (1993-1995) Front Kit (L/R)
Honda Civic 1.6 DX Coupe (1996-2001) Front Kit (L/R)
Honda Civic 1.6 HX Coupe (1996-2001) Front Kit (L/R)
Honda Civic 1.5 CX & DX Hatchback (1990-1995) Front Kit (L/R)
Honda Civic 1.5 Sedan (1990-1995) Front Kit (L/R)
Honda Civic 1.5 Wagon 2wd (1990-1991) Front Kit (L/R)
Honda Civic 1.6 Hatchback (1990-2000) Front Kit (L/R)
Honda Civic 1.6 Sedan (1994-2001) Front Kit (L/R)
Honda CRX 1.5 DX CRX (1990-1991) Front Kit (L/R)
Honda Del Sol 1.5 (1993-1997) Front Kit (L/R)
Honda Del Sol 1.6 (1993-1997) Front Kit (L/R)
LS Vtec oil line, NO ADAPTER, $40
Shift linkage, 94-01 integra b-series $40
94-01 integra
LS gauge cluster, manual with 130k. $40
94-01 Integra Glove box $20
94-01 Integra Gauge cluster bezel $10
94-01 Integra Dash kicker panel under steering column $10
Modified by HickamHatch at 9:19 PM 10/9/2008
TURBO STUFF:
Will fit:
94-01 integra
