jrsc some quick questions
Old Sep 30, 2008 | 04:37 PM
tegdude227's Avatar
Default jrsc some quick questions
i just put my jrsc on my 97 gsr and im running all stock pullys for now. and im running stocking injectors right now i have a fmu on the way. i was woundering i took it out for a drive to make sure everthing was good. and i gave it gas and my boost gauge read 4psi then the car boged and it was like something was holding it bac it was way slower then when i ran it na. is this because i dont have the fmu on it now ? now i dont really know how tight to make the belt that goes to the blower itself. so do i just tighten it till it gets hard to tighten the bolt ? any info would be great thanx
Old Sep 30, 2008 | 05:21 PM
spets's Avatar
wait for the fmu! hell, ditch the FMU setup and get it tuned. you're asking for trouble. You also need the fuel inrichment relay.
Old Sep 30, 2008 | 06:19 PM
tegdude227's Avatar
Default Re: (spets)
im just going to be running it for a few weeks with the fmu and wat is that relay ? and were can i get it at?
Old Sep 30, 2008 | 06:37 PM
spets's Avatar
well, you can get it from Jackson for 138 bucks.. but try finding a used one first.
http://www.supercharger.com/Sh...43173
just take the belt off and wait until you can get it tuned.
Old Sep 30, 2008 | 08:42 PM
rmcdaniels's Avatar
Default Re: jrsc some quick questions (tegdude227)
Boost with no extra fuel is a very good way to liberate your ring lands.
Feel the belt when you tighten it, not the bolt. Tighten it until it is difficult to deflect it 1/2", then see how it holds boost to redline (after you get the fuel situation worked out). Tighten it until it holds boost to redline.
Old Oct 1, 2008 | 03:16 AM
tegdude227's Avatar
Default Re: jrsc some quick questions (rmcdaniels)
alright i go on there site and i see a relay and a pressure switch ? and there not 135 bucks. and wat does this relay do because ive never haerd of it before. its not in this write up http://www.c-speedracing.com/howto/jrsc/jrsc.php. and ive never heard or any one using one. is it only for when you use an fmu ? and i got a blox fmu is that alright to use ?
Old Oct 1, 2008 | 03:25 AM
tegdude227's Avatar
Old Oct 1, 2008 | 07:01 AM
rmcdaniels's Avatar
The part that you circled is the pressure switch.
The correct and complete instructions for installing a JRSC on a GSR are here:
http://www.supercharger.com/gr...0.pdf
Blox and other manufacturers make FMU's with different rise rates. If the one that you get matches whatever the JR unit is, then it may work right. If it isn't, then it may not work right. Seeing as there's a JR FMU sitting on ebay at $10 right now, I'd just use the JR FMU if you're not going to get decent fuel management.
Old Oct 10, 2008 | 04:46 PM
jdmcivic88's Avatar
I installed the kit on my B16a2 and im having the same bogging problem and boost reading have you got that problem solved yet and if so what had to be done?
tsjeff
Dec 27, 2005 01:49 PM
Stingray96
11
Oct 30, 2005 01:42 PM
TOFU.man
Oct 12, 2005 07:08 PM
Green Lude 93
Sep 20, 2004 12:56 PM
