OEM Single Cam questions
Old Sep 30, 2008 | 04:33 PM
shaggyeg6si's Avatar
Default OEM Single Cam questions
Okay, so in the b-series, everyone knows which OEM cams are best. What about the single cams? What is the better cam out there while still maintaining OEM status. Does anyone have specs on this such as duration and lift? What about overlap as that is a good turbo specification?
Old Sep 30, 2008 | 04:46 PM
89s1's Avatar
Default Re: OEM Single Cam questions (shaggyeg6si)
well, in non vtec form The best cam are the Si(d16a6)/sohc ZC cam
vtec on the other hand is the jdm d15b vtec or the d16z6.
searching google for d16 cam specs will get you the rest of your info. Just be sure to check multiple sources, misinformation runs rampant on the internet.
Old Sep 30, 2008 | 04:47 PM
D16SiHatch's Avatar
Default Re: OEM Single Cam questions (89s1)
i concur with this guy ^
Old Sep 30, 2008 | 05:05 PM
Default Re: OEM Single Cam questions (D16SiHatch)
Great info. I am going to see what kind of list I can compile and get it out there. Thanks for the input. I figured a cam would be an easy upgrade without breaking the bank.
Old Sep 30, 2008 | 09:44 PM
89s1's Avatar
It is, but dont expect a whole lot from an OEM upgrade.
the d15b2 made 92hp and the d16a6 only made 108. it had mpfi, a better cam, a better intake manifold, better exhaust manifold, more displacement....
see where im going?
Old Oct 6, 2008 | 02:42 PM
I've already got an Si. More or less I am looking into cams from other generations, not just OBD0 engines.
SLOENUF
Mar 12, 2011 06:06 AM
kicked25th
Texas -OK -LA (Sales)
Jun 11, 2008 01:05 PM
Finger Lickin' good
Feb 22, 2007 09:55 AM
Que_Lude
Mar 26, 2004 05:42 PM
jdmcx
Jan 10, 2003 08:46 AM
