Rear Disc Swap.. ABS Question
i have a 2000 civic ex with abs & i picked up a rear disc swap that doesnt have abs. Can i attach ABS sensors to the rear disc swap and still have my ABS functional?? or does the whole assembly need to be built for ABS.. thanks in advance!
http://www.hondaautomotivepart...0.gif
See that gear looking thingy on Part #2. That is what the abs sensor takes its reading from. If that is not there your abs lightwill probably turn on.
The hubs must have the toothed ring for the Hall effect wheel speed sensor. Considering that the hub/bearing assemblies are essentially what you are buying for a rear disc conversion (plus the spindles, calipers, lines, and cables), it is absolutely pointless to buy non-ABS parts and expect to add the ABS bits later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ »</TD></TR><TR><TD CLASS="quote">http://www.hondaautomotivepart...0.gif
See that gear looking thingy on Part #2. That is what the abs sensor takes its reading from. If that is not there your abs lightwill probably turn on. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">The hubs must have the toothed ring for the Hall effect wheel speed sensor. Considering that the hub/bearing assemblies are essentially what you are buying for a rear disc conversion (plus the spindles, calipers, lines, and cables), it is absolutely pointless to buy non-ABS parts and expect to add the ABS bits later.</TD></TR></TABLE>
thanks.. im gna check to see if i have the teeth on the hub.. it didnt come with abs sensors so this is my only way to tell
b18ctrb
Jun 10, 2008 04:28 AM
