code 6, ect wiring problem
Old Sep 30, 2008 | 12:38 PM
thecorey's Avatar
Default NEED HONDA GURU HELP ....code 6, ECT wiring problem?
so first off..i did a search and i found the info on the faq about getting a resistor and plugging it in to see if the problem is with the sensor or the wiring. well i got the resistor (330 ohm 1/2 watt spec, or one from Radio Shack part# 271-1113) and i still get a cel and bad idle. so i'm guessing the problem is with the wiring? can anyone tell me how to further diagnose this problem...maybe with a multimeter or something. or even explain how to hardwire my sensor to the ecu. i think i found 1 pin for the ect on the ecu, but there are 2 wires on the sensor...so im not sure how to hook it up.
update. i used a multimeter to test the red/white wire and i get 5v's with the key on. on the sensor and at the ecu. when i turn the car on i get the voltage changes slowly so it seems the sensor is working...when i tested it...it was at 1.7v's and the car was somewhat warm...not completely warmed up though. any thoughts?
by the way...the car is a 89 crx HF with a obd0 b16. and the code comes on instantly when i move the car.
Modified by thecorey at 5:24 PM 9/30/2008
Old Oct 1, 2008 | 09:50 AM
thecorey's Avatar
Default Re: NEED HONDA GURU HELP ....code 6, ECT wiring problem? (thecorey)
bump
Old Dec 8, 2008 | 06:53 PM
wwcrxww's Avatar
Icon3
i also need to know where the other wire goes... i know it goes into a connector along with several other wires from other sensors. idk if its a ground or what but bump this
Aposiopesis
Nov 12, 2017 06:18 PM
Rob91DA
Nov 20, 2008 09:26 AM
91tegrals
Nov 28, 2005 08:41 PM
axhandler
Jun 18, 2003 08:33 AM
evil_elmo
Apr 16, 2002 05:48 PM
