Coolant leak from timing cover
Old Sep 30, 2008 | 12:24 PM
matter99's Avatar
Default Coolant leak from timing cover
1992 accord 4cyl leaks coolant from timing cover.
Seems to be worse when front end of car is higher than back end.
Drips about a gallon a day when tipped back. Otherwise maybe a pint when car is parked level.
I'm curious what behind the cover might leak. Would I have to remove both covers or just the upper? Something I can tackle in my garage with mild mechanic skills/tools - or better to blow several hundred dollars at the dealer?
Thanks!
Old Sep 30, 2008 | 01:09 PM
waciii's Avatar
Default Re: Coolant leak from timing cover (matter99)
The water pump is behind the timing cover. FAQ covers how that's done.
Chriser0
25
Jul 31, 2013 07:09 AM
d4rk13l4de
May 4, 2009 09:02 PM
daylon1650
Feb 10, 2009 06:55 PM
shifts
Apr 8, 2008 08:58 PM
thizboii
Apr 21, 2007 06:18 PM
