need help with valve spring comparison please!
Old Sep 30, 2008 | 11:48 AM
exotik4doorcivic's Avatar
Default need help with valve spring comparison please!
want to know if these will be fine to use with blox b's
i bought these off a friend who said he bought a head package from a machine shop and they said theyre supertech but they look like stock springs!
the inner spring is taller than stock and the retainer looks like its titanium
and the inner spring clips into the retainer but the stock spring doesnt
i installed them in my head but removed one of them because i was concerned because they have the same blue paint as a stock gsr spring
LEFT IS THE ORIGIONAL GSR SPRING
also remeber reading that the aftermarket springs have no area were the coil springs are closer together on one side but both of these have that?
Modified by exotik4doorcivic at 8:54 PM 9/30/2008
Old Sep 30, 2008 | 02:57 PM
Default Re: need help with valve spring comparison please! (exotik4doorcivic)
UPDATE!
went to a machine shop and we measured the spring pressure
stock spring was 50lbs
and the setup i had was 75lbs of pressure he said the outside spring was stock but the inner spring and retainer are aftermarket
he said they should be fine up to 9500 rpms? does this sound right?
going with blox b's in a gsr with jdm itr pistons and arp rod bolts
any input??
Old Sep 30, 2008 | 05:34 PM
bump for help
Old Oct 1, 2008 | 05:05 AM
ef92b's Avatar
you're better off getting a new set and throw that trash in the bin.
Old Oct 1, 2008 | 05:47 AM
92integraVTECgsr's Avatar
Default Re: need help with valve spring comparison please! (ef92b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef92b &raquo;</TD></TR><TR><TD CLASS="quote">you're better off getting a new set and throw that trash in the bin. </TD></TR></TABLE>
That's what I would do. If I don't know what I got 100%, I won't use junk. Just buy some new Supertech Valve springs if that is what you want. Then you know and have piece of mind.
Old Oct 1, 2008 | 07:53 AM
Default Re: need help with valve spring comparison please! (92integraVTECgsr)
should i get the max lift checked out on the ones i have first? the machine shop told me ill be fine taking it up to 9500 rpms and with the blox b's/jdm r pistons i should only make power up to 9k- right?
dumlq
Jul 27, 2013 02:13 PM
sakasaku
May 22, 2008 06:56 PM
thehatchninja
14
Sep 2, 2005 08:57 PM
sarniacivic
Dec 20, 2003 04:11 PM
