Timing Help. Trial and Error and Searched. Frustrated!
Old Sep 30, 2008 | 05:53 AM
96 EX's Avatar
Default Timing Help. Trial and Error and Searched. Frustrated!
Ok so after weeks of reading about what to do about my mis-firing problem I decided to re-set the timing on the crank and cam shaft after it had slipped a belt. Me and a buddy of mine ripped into it one morning and got it all back together to find it to run better. The problem is I still have a ECU for random misfires throughout all cylinders. Now if I go beyond 3500 rpms my check engine light gets brighter as I climb the rpms. I hooked a timing gun up to it last week and notice something odd. At first when we hooked up the timing gun the #1 cylinder was firing as the same time the crankshaft was lined up with the markings on the block. But after a couple seconds it would begin firing at a different time. This brought me to the conclusion of maybe my tensinor is loose?? I have no idea but would like to get this problem fixed before it detonates.
Old Sep 30, 2008 | 06:06 AM
B16SolMan's Avatar
New User
Your jumping teeth--get a new spring on your tensioner or make sure that bolt is actually tightened up--easy thing to forget when reinstalling
Old Sep 30, 2008 | 06:45 AM
96 EX's Avatar
Default Re: (B16SolMan)
Alright I'll go home an tear it apart and double check everything cause I know that we had it on TDC. If its not the spring or the tensinor then what could it be??
Modified by 96 EX at 8:02 AM 9/30/2008
Old Oct 1, 2008 | 11:47 AM
B16SolMan's Avatar
New User
How new is the belt? and which cylinder are you putting at top dead center when you put it all back together--the fact that the timing changes leads me to believe that you're jumping teeth, do a compression check as well, always a good thing to do to eliminate certain possibilities.
DraginTeg93
Jan 29, 2010 12:02 AM
slowpokesi
Feb 19, 2005 06:39 PM
1987CRXSi
Dec 29, 2004 07:12 AM
carcala
Jan 18, 2003 04:06 PM
slowassgsxr750
Jan 11, 2003 10:23 AM
