Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
DIY HELP! Springs.
Old Sep 29, 2008 | 10:08 PM
JTaudio0212's Avatar
Default DIY HELP! Springs.
I put on eibach sportlines last night and took it for a test drive and there's a knocking/popping noise coming from the *** end (passenger rear to be exact) and I have no idea what to do. I did notice the front is perfectly even on both sides but the rear drivers side is about a half an inch higher then the rear passenger side. I tried taking it apart again, readjusting the spring, making sure everything was tight, letting it sit for a while to settle and nothing seems to work, it is still making a noise. It sounds like real quick metal to metal bang, not really a drawn out rubbing sound. It happens during normal driving (very minimal bumps) and obviously gets a little worse when there's a bit bigger bumps in the road... and I am totally done messing with it for the night...
I know you guys know your stuff and I would love your help.
Thanks!
Old Sep 29, 2008 | 10:30 PM
pd0019's Avatar
Default Re: DIY HELP! Springs. (JTaudio0212)
did you make sure everything is back on nice and tight and that your spring is seated properly?
random question, but did mess with your swaybar besides loosening it from its endlinks?
Old Sep 29, 2008 | 10:37 PM
Default Re: DIY HELP! Springs. (pd0019)
I followed the DIY from 8thcivic to a T. But yea I took off the bottom part of the sway bar off, not just loosened... and everything went smooth, besides for the F-IN noise.
Old Sep 30, 2008 | 12:22 AM
knaira112387's Avatar
doesnt seem seated.
Old Sep 30, 2008 | 09:41 AM
Default Re: (knaira112387)
I fixed it, it was something really really dumb, The top nut on the sway bar wasn't all the way tight, and I mean I couldn't even move it with my hand to reproduce the noise, but it tightened about half a turn more then it was with some superman strength and the noise is gone... thanks for the help guys, and especially pd0019.
This is why I love honda-tech.
Much appreciated.
Old Sep 30, 2008 | 01:18 PM
pd0019's Avatar
Default Re: (JTaudio0212)
i had a feeling it had to do with your swaybar b/c i didnt install my progress swaybar properly and my car was making the noises you described.
glad your problem was solved
Old Sep 30, 2008 | 06:50 PM
Default Re: (pd0019)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pd0019 &raquo;</TD></TR><TR><TD CLASS="quote"> i had a feeling it had to do with your swaybar b/c i didnt install my progress swaybar properly and my car was making the noises you described.
glad your problem was solved</TD></TR></TABLE>
Yea dude, I appreciate it, you have no idea!
khronicboy420
Suspension & Brakes
Mar 24, 2011 09:23 PM
JTaudio0212
Suspension & Brakes
Oct 1, 2008 01:14 PM
sweetnhigh
Honda Civic (2001 - 2005)
Jul 15, 2006 01:37 PM
deviant1
Dec 3, 2003 05:41 PM
