1992 Accord Need Help
Old Sep 29, 2008 | 04:51 PM
stevo4916's Avatar
Default 1992 Accord Need Help
I have a 1992 Honda Accord and I am having problems with the car overheating while im idling in traffic once I continue with normal driving though the temperature returns to normal. The fluid levels are normal and I replaced the thermostat....any suggestions on what the problem could be? O and by the way the Fans do work and turn on while the car is at idle....
Old Sep 29, 2008 | 05:35 PM
hondadude's Avatar
Default Re: 1992 Accord Need Help (stevo4916)
Sounds like a poor flow problem......plugged up radiator?
You can check for temp difference between the top and bottom hoses.
T-stat not opening fully could cause this too.
Have you opened the bleed valve to be sure there is no air trapped in the block?
ThatCarFellow
Sep 12, 2018 08:20 AM
Terri McCuien
Aug 9, 2012 03:43 PM
faran
Aug 13, 2010 07:06 PM
95white
Feb 9, 2007 03:36 PM
accordtype R
Dec 20, 2005 03:42 PM
