Will CTR or ITR cams pass smog in a GSR
Old Sep 29, 2008 | 02:09 PM
ef8-dc2619's Avatar
Default Will CTR or ITR cams pass smog in a GSR
Like title says. Just wondering since I live in so-cal, I have a stock 00 GSR. plans are not too crazy with her.
plans:
cat-back
i/h
stock cr
valve train
CTR or ITR or crower 401
NA IS BEST!!!
Old Sep 29, 2008 | 04:03 PM
garados's Avatar
Default Re: Will CTR or ITR cams pass smog in a GSR (ef8-dc2619)
yes, when I had my 95 gsr, I put 98 ITR cams in and I did better on the smog test than with the gsr cams Remember, when modding a car that gets emission tested, make the modifications inside the engine. They're out of sight and away from CARB ... but don't hold me to that
Old Sep 29, 2008 | 09:46 PM
dc2_916's Avatar
i passed with stage 1 crower cams,cam gears,skunk2 IM,headers,exhaust,and full exhaust like couple days ago.. all i did was bought a new cat and used my stock ecu.. passed with lowass numbers.im plannin on gettin pistons also..
Old Sep 29, 2008 | 11:44 PM
racebum's Avatar
Default Re: Will CTR or ITR cams pass smog in a GSR (dc2_916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">i passed with stage 1 crower cams,cam gears,skunk2 IM,headers,exhaust,and full exhaust like couple days ago.. all i did was bought a new cat and used my stock ecu.. passed with lowass numbers.im plannin on gettin pistons also.. </TD></TR></TABLE>
there's your answer, crower 401s are basically CTR cams. the guy above also had the same experience. personally, i'm in the same boat with 401s. bought them because they are such an easy cam to set up and pass with, killer MPG too.
Old Sep 30, 2008 | 02:08 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: Will CTR or ITR cams pass smog in a GSR (idrivesideways)
itr and ctr should they are honda oem products
Old Oct 1, 2008 | 06:54 AM
ef8-dc2619's Avatar
so what about tuning? I know if the motor is tuned it will run better than not tuned
but I thought chipped ecu's is not smog legal or hondata; I dont know
Thanks for the replies guys!!
Old Oct 1, 2008 | 09:36 AM
racebum's Avatar
depends on the state. if they only do the sniffer you're cool with hondata. if they plug in you might want a type r ecu. i think this is half the reason usdm p73s cost $200 or so
Old Oct 1, 2008 | 09:41 AM
garados's Avatar
For the tuning aspect, I was doing fine with a VAFC (adjust the vtec engagement higher). I don't remember if it throws a code on an obd2 car, but I doubt it. Anyways, you'll be fine with just the gsr ecu for smog. The vtec engagement will be a little low, but the car will run fine and there won't be any codes = pass on the emissions test.
Old Oct 1, 2008 | 09:49 AM
ef8-dc2619's Avatar
ok, so P-73 ecu and = smog legal with type r cams
so what do I need the P-73 ecu to be odb2a or obd2b? (my car is a 00)
Old Oct 1, 2008 | 09:55 AM
garados's Avatar
you're going to want an obd2b ecu. Be sure to check your ecu, though, just to make sure. There are 4 plug receptacles on your ecu, but only 3 are used. OBD2a uses 1,3, and 4 and the 2nd one is empty. OBD2b uses the first 3 and the last one is empty.
Old Oct 1, 2008 | 10:08 AM
ef8-dc2619's Avatar
Default Re: Will CTR or ITR cams pass smog in a GSR (garados)
jdm or usdm ecu?
Old Oct 1, 2008 | 10:11 AM
racebum's Avatar
obd2b has that immobilizer. this one is above my level. someone must know how to setup a p73-a04 in the 00-01 cars. do the just plug in or is something required for the immobilizer?
mynameizstitch
Northern California
Jul 22, 2009 09:46 AM
theslugbug
Jul 20, 2009 04:00 PM
mynameizstitch
Jul 8, 2009 11:43 AM
hmongyaj87
May 15, 2007 12:35 PM
broketuner-Sol_Si
10
Feb 20, 2006 08:02 AM
