need help with 2000 gsr oem exhaust!
Old Sep 29, 2008 | 12:50 PM
OBDII Integra's Avatar
Default need help with 2000 gsr oem exhaust!
hey whats up guys?...my aftermarket exhaust went to **** so i got rid of it and my friend hooked me up with a factory exhaust from a gsr which is what i orginally had before i did the exhaust...well i went to bolt everytihng up and the header wouldnt work, it seemed to long and the bolt holes on the header wont line up with the cat...so my friend gave me another set to try and still same thing....my question is with a facotry gsr exhaust do i HAVE to use the gsr oem header or will something else work, and keep in mind i want to keep it bolt on, no welding or cutting cause i cant get to any of that right now...any info would help, thank guys
Old Sep 29, 2008 | 01:27 PM
Default Re: need help with 2000 gsr oem exhaust! (OBDII Integra)
anyone??
Old Sep 29, 2008 | 01:40 PM
salomon16's Avatar
I had the same problem once. It was too long so I cut a section out, used a 2" exhaust coupler to reconnect the two ends of the pipe, rotated the flange to bolt up to the cat, and welded it all in place..
Old Sep 29, 2008 | 02:36 PM
Default Re: (salomon16)
what would be my options if i couldnt cut or weld?
Old Sep 29, 2008 | 02:39 PM
TunerN00b's Avatar
Default Re: (OBDII Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDII Integra &raquo;</TD></TR><TR><TD CLASS="quote">what would be my options if i couldnt cut or weld?</TD></TR></TABLE>
Take it to an exhaust shop and have them do it.
Alternative, is to get a flex coupling, a couple of exhaust clamps, and a hack saw from Pep Boys.
Old Sep 29, 2008 | 02:49 PM
Default Re: (TunerN00b)
now if i find an oem gsr header to go with the gsr piping, there shouldnt be a problem fitting rgiht? or will i still be screwed?
Old Sep 29, 2008 | 02:50 PM
salomon16's Avatar
ditto what tunernoob said. Find a friend with a sawzall or hacksaw and do some work...invest in a sawzall if you have the money you'll be glad you did.
you can use the coupler and clamps instead of welding, and get it welded later (cheap at a muffler shop)
Old Sep 29, 2008 | 02:51 PM
salomon16's Avatar
dont bother finding another manifold just modify it a little and save yourself the time and money
Old Sep 29, 2008 | 03:41 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Theres a shop over here that only charges like 15 bucks to get that fixed, me and all of my friends have gone there plenty of times when our piping is too short or too long
gsr_b20b
Jan 16, 2011 03:24 AM
Malakai
Jun 29, 2010 07:57 PM
WillyD6869
Jul 28, 2005 10:29 PM
.doeboyfresh.
Aug 23, 2004 06:31 PM
Comtechgsr2000s
Nov 18, 2001 05:05 PM
