FS 90 Ford Probe GT Turbo
Old Sep 29, 2008 | 11:50 AM
cticknor666's Avatar
Default FS 90 Ford Probe GT Turbo
Well as always i get bored with cars way to easy. So im tossing this up to see if theres any interest. Its a 1990 Probe GT. She's got 154,xxx miles on it, the previous owner said the motor has been rebuilt and i belive it. Compression numbers are solid across the board. i found a dig cam memory card in it when i bought it from the previous owner before the guy i got it from. Had pics of the motor tore down and being rebuilt so im pretty sure it was. Runs excellent with zero problems. The roof is pretty dinged up since it was in a hail storm and theres a few places on the body. Car has 2 brand new axles that i just put in, along with a new shifter to replace the crappy cut one that was in it. Has a brand new spec stage 1 in it with only about 500 miles on it maybe less. 2.5 downpipe to 2.5 exhaust Custom 3 inch intake with the vaf Relocated under the battery. DSM bov recirculated. Custom hard pipes and FMIC. Autometer carbon fiber boost gauge. Swapped to manual seats. Has 1g turbo wheels on it now instead of the 2g SE wheels. White face gauges. Newer brakes. I have a set of Window Welded mounts that will go with the car if i dont put them in first. New plugs, wires ect. Car is also chipped with a probinator chip, manual boost controller set to 15psi. Has BRAND new Falken Ziex 912's on it with maybe 150 miles on them. Car has ran a best of 14.6 and has alot more in it on stock turbo, a set of drag radials or slicks and high 13's shoudlnt be a problem.
Things the car needs or could use:
90GT drivers door and fender, it has a 89 door and fender on it now that look fine but dont look right on a 90, the door has a lil hang to it and the fender has a creese.
The steering is starting to get a little sloppy a sign of a wearing steering rack, its not bad tho and i daily drive the car and put probably 150 miles a week on it no problem.
Paint, its not too bad but it wouldnt hurt to have a good paint job.
Anyway thats all i can think of right now, any questions just ask and i'll answer anything.FYI i would not hesitate to drive this car anywhere, runs very good and gets good gas mileage. Dont have recent pics but i will take some tomm and post them up. Asking 1400 for her.I found a car i want so this HAS TO GO. 1400 is as low as im going tho. Also i have quite a few parts that can go with this car for a bit extra.
I can get any pictures that you want just request them if you dont like what you see.
suckerpunch
May 12, 2010 02:07 PM
cticknor666
Jul 26, 2008 12:09 PM
quik sol
Jul 20, 2007 09:52 PM
ILLICON5000
May 29, 2006 08:14 PM
Hatch-E
Jul 21, 2003 01:05 PM
