type r cams?
i will be putting in jdm spec ctr cams in my jdm b16a next week and was wondering if i had to adjust the valves in any special way. also i have sk2 intake manifold to put on to and was wondering what size tb would be the best for the cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-b18c »</TD></TR><TR><TD CLASS="quote">62mm</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civiclover »</TD></TR><TR><TD CLASS="quote">i will be putting in jdm spec ctr cams in my jdm b16a next week and was wondering if i had to adjust the valves in any special way. also i have sk2 intake manifold to put on to and was wondering what size tb would be the best for the cams
yes you need to always check and adjust clearance when you remove cams. i would suggest breaking them in too, idle them at 2k for about 15-20 mins, before you beat on them.
</TD></TR></TABLE>yes you need to always check and adjust clearance when you remove cams. i would suggest breaking them in too, idle them at 2k for about 15-20 mins, before you beat on them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">I hope you got aftermaket valvesprings</TD></TR></TABLE>
naw man its good to run them on the stock springs!
purplehaze_95
11
Jun 30, 2005 09:32 PM
