HVAC vent selection buttons
Old Sep 29, 2008 | 09:48 AM
hondasaurusrex's Avatar
Default HVAC vent selection buttons
alright guys, i've searched here and on other forums and havent found any info, so here it goes
89 crx si, push button vent selection panel...all wires/connections are hooked up right, and everything worked fine for the longest time, but now its stuck on the floor/main vent blend setting, and i need defrost badly..... and none of the "status lights" work anymore (little light above the button to tell you what its set on)
the temperature blend **** works fine, blower motor works fine on all settings, ac button will still illuminate, i've checked every fuse in the car and theyre all fine...
so my question is, does anyone have experience with this particular glitch? is there some easy fix that im overlooking? i've had the controls out of the dash and cleaned every connection, both the male and female ends, re-installed and no dice...im hoping i dont have to replace the whole HVAC control...
arziffel
Jan 31, 2012 05:13 AM
85_305
Honda Civic (2001 - 2005)
28
Jun 27, 2009 09:33 AM
EG-Kaos
14
Jan 1, 2009 07:06 PM
