b20vtec pistons?
Old Sep 29, 2008 | 08:42 AM
Ryan#1's Avatar
Default b20vtec pistons?
So, I'm buidling a b20vtec using a b16 head and I'm looking for a compression ratio of around 11:1 A little more or less is ok with me. It's going to be all motor (obviously) and daily driven. So a forged pistons isn't necessary for me. I'm wondering if you guys can recommend me a piston in the price range of around $300-$400 that will get me my desired compression ratio. I am open to useing a b20Z piston but it's my understanding that there is valve clearance issues and it's not as high as I want. If I end up using those, is there enough material on the piston to machine them for the clearance they'll need?
Thanks
Old Sep 29, 2008 | 06:37 PM
slomofo's Avatar
GDD Member
I used to run JE forged pistons when I owned a Honda, they were like $360/set. with rings and pins and they never gave me any problems.
Old Sep 30, 2008 | 09:34 AM
Ryan#1's Avatar
Default Re: (slomofo)
That's cool i'm not opposed to JE pistons, Where do I find them for $360? Their website has them for over $600 and the SRP pistons for over $500? While those pistons are fine by me they don't exactly fit my budget.
Old Oct 1, 2008 | 08:52 AM
Ryan#1's Avatar
that's it huh? No one else? is this in the wrong forum, it is a technical question.
Old Oct 1, 2008 | 11:14 AM
LastGenEK's Avatar
Default Re: (Ryan#1)
wiscos there in the 400 hundred range
summitracing.com
Old Oct 2, 2008 | 06:27 PM
blankeyjet's Avatar
Default Re: (LastGenEK)
RS pistons are pretty cheap. You should be able to pick them up for a little over $300
Spectrum24x
Mar 9, 2006 07:14 AM
PrecisionH23a
Mar 17, 2005 06:12 PM
crx1856
Nov 3, 2003 12:00 AM
TurboT
Nov 28, 2001 01:42 PM
