fan questions
ok so i pulled out my entire ac system and i have after market radiator and slim fan as well and i hooked it up correctly to the oem fan wire harness and it does not turn on two question.
how do i know if the cooling fan switch/sensor is bad or good is there a way to test it?
second question if i wire a fan up to the condensor fan wireing harness and i push the ac button in my car will that fan come on even thought none of the other ac stuff is there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveharrmr23 »</TD></TR><TR><TD CLASS="quote">ok so i pulled out my entire ac system and i have after market radiator and slim fan as well and i hooked it up correctly to the oem fan wire harness and it does not turn on two question.
second question if i wire a fan up to the condensor fan wireing harness and i push the ac button in my car will that fan come on even thought none of the other ac stuff is there?</TD></TR></TABLE>
Turn the ignition switch on, then jump the radiator fan switch socket (the one that plugs into the sensor on the thermostat housing) with a wire. The radiator fan should turn on.
Alan Da Silva
Jul 5, 2017 09:22 AM
