which size cat?
Old Sep 28, 2008 | 09:50 PM
GsDAteg's Avatar
Default which size cat?
I'm about to buy a magnaflow cat for my DA but I'm not sure which size I should buy. I have a OBX header which has a 2" collector on it but my catback piping is 2.5". So would I want to get a 2" cat or a 2.5" cat?
Old Sep 29, 2008 | 03:54 AM
billabong's Avatar
Default Re: which size cat? (GsDAteg)
you need the cat with the 2inch collector nd a 2inch outlet
Old Sep 29, 2008 | 10:43 AM
racebum's Avatar
Default Re: which size cat? (billabong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billabong &raquo;</TD></TR><TR><TD CLASS="quote">you need the cat with the 2inch collector nd a 2inch outlet </TD></TR></TABLE>
sounds like you need the direct fit for your DA. those 2.5" catbacks are usually crimped down to a 2" collector where it bolts up to the cat if they are designed for factory fit.
Old Sep 29, 2008 | 03:06 PM
omnirage's Avatar
Don't waste your money...your exhaust is only as big as the smallest part. You may just want to build a true 2.25" header-back system.
GsDAteg
Feb 25, 2009 09:17 AM
skynyrd006
Sep 24, 2006 06:18 PM
LoseRPunKx182
Sep 10, 2005 04:09 PM
one slow coupe
Jan 18, 2005 10:29 AM
hondaeg8
Mar 18, 2004 04:25 PM
