Building a B16a Head. Info needed.
Is Partying at your House
Ok, I've never built a head, or taken an engine apart. I have found some posts about instalation of the valve train. I purchased valves, dual valve springs, titanium retainers, and a S2 test pipe for my 88 CRX with a B16. All of the valve train is SUPERTECH. Valves are (std) size.
Part #'s
Valve springs: SPR-H1002D
Retainers: RET-K20A2/T2
Valves Intake: HIVN-1000
INTAKE VALVE
33.00mm(Std) Dish Head Diameter
5.48mm Stem Diameter
102.50mm Length
BLACK NITRATED
Valves Exhaust: HEVN-1000
EXHAUST VALVE
28.00(Std) Dish Head Diameter
5.45mm Stem Diameter
102.50mm Length
BLACK NITRATED
I know I can install all of this myself, but what else do I need? As for cams, I am going to purchase Skunk 2 stage 1's, because they are carb legal in California.
Will this setup be decent N/A??? I want to go F/I in the future, but need to find a CARB legal Gerddy kit for a DelSol, or a JRSC for a DelSol.
Any help is appreciated, Thanks Alex
Part #'s
INTAKE VALVE
102.50mm Length
BLACK NITRATED
EXHAUST VALVE
102.50mm Length
BLACK NITRATED
I would also suggest changing out the valve seals and getting a valve job done as well, since you are going to have the head apart anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">I would also suggest changing out the valve seals and getting a valve job done as well, since you are going to have the head apart anyway.</TD></TR></TABLE>
get the head port and polished while your at it. But since your bulding it minus well go with stage 2 cams. No cop is ever going to know its not legal.
Valve seals? Are there aftermarket seals, or just buy stock 00 SI valve seals?
The B16 I have in my REX is strong... Perfect compression, no burning oil. I also passed Cali BAR with it.
Im looking for a B16 longblock to build up. I don't wan't to mess with this engine, because it runs perfect.
In Cali, and for myself, it has to pass smog...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xileap2 »</TD></TR><TR><TD CLASS="quote">
But will stage 2 cams pass smog legit? Skunk 2 stage 1's come with a carb #.
get the head port and polished while your at it. But since your bulding it minus well go with stage 2 cams. No cop is ever going to know its not legal. But will stage 2 cams pass smog legit? Skunk 2 stage 1's come with a carb #.
im from southern cali and I ran all type r cams, pistons, skunk 2 manifold, port and polish heads and toda headers on my old DA LS/Vtec definately wouldn't pass smog, but then again every person in H-T has a hook up 2 pass smog.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa »</TD></TR><TR><TD CLASS="quote">
Either, as long as they get replaced. Supertech valve seals are pretty affordable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xileap2 »</TD></TR><TR><TD CLASS="quote">im from southern cali and I ran all type r cams, pistons, skunk 2 manifold, port and polish heads and toda headers on my old DA LS/Vtec definately wouldn't pass smog, but then again every person in H-T has a hook up 2 pass smog. </TD></TR></TABLE>
i would reccomend going stage 2, thats what i have and love it. Also while the heads apart i would reccomend a good P&P. Fukc bar, thats all im saying about that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 »</TD></TR><TR><TD CLASS="quote">
i would reccomend going stage 2, thats what i have and love it. Also while the heads apart i would reccomend a good P&P. Fukc bar, thats all im saying about that</TD></TR></TABLE>
Im already BARRED, I just want to pass smog legaly... What power are you putting down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 »</TD></TR><TR><TD CLASS="quote">i would reccomend going stage 2, thats what i have and love it. Also while the heads apart i would reccomend a good P&P. Fukc bar, thats all im saying about that</TD></TR></TABLE>
agree
agree
jdmjeff
Dec 21, 2005 02:18 PM
7rrivera7
Nov 7, 2005 03:11 PM
