HOLY CRAP! tons of B series and 92-95 civic goodies
ENGINE/TRANS/SWAP PARTS
new oem headgasket for 81-82mm LS/VTEC - 30
old school str competition fuel rail, B series - 70
rage racing 4-2-1 header - 300
great condition used 81.5mm JE 12:1 CR pistons - 180
b18a crankshaft , fresh micro-polished, mic'ed, - 90
b series hydro half shaft - 40
240cc injectors - 20 for all four
2000 miles on INNOVATIVE limited edition bronze billet poly motor mounts for b series in 92-95 civic - 200
new hydro slave cylinder B or D series... - 10
very low miles hyper pressure plate with act 6 puck sprung clutch disc for B series hydro transmission- 100
new ls/vtec stealth performance oil feed line with fittings- 20
camp 1320 insulated IM gasket - 15
b16 main caps, engine will need align hone if not using original main caps- 20
2 pairs of b series axles..one set for 88-91 civic other for 92-95 civic - 50 each or 80 for the pair.
generic 3 inch intake arm for ef/eg/ek with filter - 10
2 sce copper exhaust manifold gasket for b series vtec... 10 each
b16 crank - 30
stock b series cam gears - 10
b18 block...freshly decked, needs to be overbored to at least 81.75mm in order to be round again...still good for sure - 50
new b18a stock rods, flash lines have been polished off, shotpeened and resized after arp rod bolts, rod bolts and hardware included - 150
b16 head with rockers and stock cams,no valvetrain , fresh resurfacing done,will include new guides and seals(already intalled) - 200
complete 2.5 inch custom catback exhaust for 92-95 civic coupe... has a real 18 inch resonator and sebring straight through muffler....flanged over the axle for easy removal of muffler....sounds quiet down low and roars up top...very nice exhaust...cost me nearly 300 for all the materials... 150 obo
ELECTRICAL
chipped pr4 ECU - 80
engine harness for 92-95 civic dx - 80
body harness for 92-95 civic coupe - 100
b series alternator obd 0 - 40
2 vtec solenoids - 30 each
msd blaster ignition coil - 30
3 iacv for d or b series - 20 each
92-95 CIVIC
92-95civic/94+ integra manual pedal assembly - 50
half radiator for eg with fan and shroud - 40
lightweight billet rear LCA for 92-95 civic - 80
whitfield racing traction bar for 92-95 civic...chrome moly construction with spherical rod ends - 200
92-95 great condition arctic white dx doors complete w/ moldings,windows,door handles,dx door panels - 60 each
92-95 oem civic coupe sideview mirrors - 40 pair
92-95 civic coupe white rear bumper - 40
good grey steering wheel airbag for 92-95 civic steering wheel - 30
new energy suspension polyurethane bushing master kit for 92-95 civic/94+ integra- 70
92-95 civic white driver and passenger CX doors...they are a little banged up, but would be perfect to gut for the track...comes with functioning windows and door handles... - 40 for the pair
88-91 CIVIC
88-91 civic headlights - yellow highbeams 35 each or 60 for the pair
88-91 civic hatch tailights w/ all red center garnish - all for 60
90-91 civic oem rear bumper...never painted - 60
wings west whale tail for 88-91 civic hatchback, very rare - 100
MISC
97-01 prelude aem V2 intake arm w carb sticker... 40
autometer 5 inch tach w/ adjustable shift light - 60
i have tons of honda specific bolts, let me know what you need.
SOLD:
MAXBORE ported gsr TB..67mm to 62mm taper - 50
act lightweight flywheel 12 lbs - 80
92-95 civic coupe good condition white fender - 40
92-95 civic si door panels, black - 40 pair
cluster from 92-95 civic si 150k miles, built in tach - 50
92-95 civic coupe white trunklid, great condition, with license plate frame - 60
aebs b16/itr intake manifold - 90
b&m FPR - 20
sk2s2 cams w/ AEM silver cam gears- 350
94-01 gsr rear engine bracket - 30
99-00 civic si driver side 2 post engine mount bracket - 30
camp 1320 insulated tb gasket - 5
chipped pr3 ECU - 100
supertech dual valve springs and titanium retainers with locks - 180
shift linkage for b series into 92-95 civic/integra, all poly bushings and has short shifter-90
great condition grey ek front seats - 60 pair
obd1 b16/gsr distributor - 100
92-95 civic oem headlights -50 each or 80 for the pair
92-95 civic coupe oem taillights - 30 each or 50 for the pair
b16 valve cover - 30
b16 shortblock - 100
supertech standard size flat face high compression b series valves set- 100
gsr tranny - has a slight grind on 1-2 shift at high rpm averything else is perfect-200 new ARP head studs for LS/VTEC - 100
b series starter - 30
throttle cable for b series into 92-95 civic - 20
92-95 civic front bumper - 20
i have tried to price everything as fair as possible..so im pretty firm on pricing, but always willing to make a deal...especially if you are interested in buying more than one item...
all parts are located in pasadena, but i live in the valley, and willing to meet anywhere within the area...give me a call anytime.
cell- 626 354 5526... my name is shant...i can take pics of anything upon request...
Modified by Suck my DX at 10:28 PM 10/13/2008
Modified by Suck my DX at 9:25 AM 10/19/2008
b16 crank - 30
ELECTRICAL
92-95 CIVIC
88-91 CIVIC
MISC
SOLD:
b&m FPR - 20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuniepatuni »</TD></TR><TR><TD CLASS="quote">too much to read. lol what kind of radiator? and u got the driver side window regulator</TD></TR></TABLE>
lol you say it like its a bad thing...
the radiator and fan assembly came off a 95 civic dx...oops i should fix that post it meant to say SOHC...i dont know if there is a difference between the two, so id like to clear it up...i had it on a b series application and would cool it fine...
im trying to sell my second set of doors as drag doors...
thanks...hopefully i can sell this stuff to finish my other projecs...
i will take pics of as many things possible tomorrow...ive just been having a hard time finding a camera...
lol ill keep adding parts as i remember them...im sure theres a lot of stuff im forgetting...
yo i got that window regulator u need
the whole side actually
Awesome stuff! Will begin counting pennies to see what I can and cant grab off the list.
BUMP
Nice prices.
BUMP
Nice prices.
thanks guys...sorry no pics today...extremely busy at the shop, had no time to focus on my own car...
thank you for everyone that has been calling expressing interest....i will try to get as many new parts as possible to add to the list at great prices!
